Cherry: moving from oil-based to waterborne poly
Forum topic by CharlesA posted 03-11-2016 10:26 PM 1405 views 1 time favorited 13 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3339 posts in 1915 days
03-11-2016 10:26 PM
Topic tags/keywords: cherry question
i use a lot of cherry and my favorite finish is satin Arm-R-Seal. I use it plain, and after a few months the cherry has darkened to a perfect color. It’s foolproof.
So . . . I’ve decided to fool with it. I’ve been using more General Finishes High Performance poly. I like it for two reasons: 1) now that I’ve learned to spray it, I can get a really nice finish in way less time. 2) Water-based clean-up is much more convenient in general.
I’ve been thinking of how to achieve the finish I get with Arm-R-Seal. I was wondering about using orange/amber shellac (i’d play with the tone) and then cover with the HP poly. I assume it will age and darken and come out long term the same way. Is that correct? Anyone else use waterborne poly that achieves the aged finish naturally.
13 replies so far
View ChefHDAN's profile
ChefHDAN
1122 posts in 2967 days
#1 posted 03-11-2016 11:15 PM
Charles, this table is 4 years old in this picture, coated with BLO and then sprayed with WB poly. I used the same process for an entertainment center I just finished and I’m going to try and watch it better to see how long the tone shift took.
At 4 years
When 1st finished
View bkseitz's profile
bkseitz
295 posts in 1427 days
#2 posted 03-11-2016 11:20 PM
That is a beautiful a beautify table. Love the inlay border
-- bkseitz, Washington "if everything is going well, you've obviously overlooked something"
View Clint Searl's profile
Clint Searl
1533 posts in 2478 days
#3 posted 03-12-2016 01:48 AM
You don’t need no stinkin’ under-finish, especially BLO. Start with a 20% thinned coat of the waterborne, smoothed back to 220, followed by as many straight coats to get the build wanted. The cherry will darken naturally.
CharlesA
#4 posted 03-12-2016 01:52 AM
The reason I was considering shellac undercoat is because the one time I used straight waterborne on cherry ( on a lied I don’t have access to so I can’t see how it turned out after darkening), I didn’t like the pinkish cherry color. The arm-r-seal darkens it enough for me initially.
View Scott C.'s profile
Scott C.
160 posts in 2168 days
#5 posted 03-12-2016 01:59 AM
you might try messing with a water soluble dye added to the poly since your spraying. You’ll have to experiment but it’s a great way to warm up water white poly.
-- measure twice, cut once, swear and start over.
View bearkatwood's profile
bearkatwood
1632 posts in 1129 days
#6 posted 03-12-2016 02:00 AM
The shellac would seal the grain and stop that fuzziness from the water based finish nicely I think as well. Sounds like a good combo Charles and you could use a tint to get the color shade you are hoping for. Hope it works out well.
-- Brian Noel
CharlesA
#7 posted 03-12-2016 02:50 AM
you might try messing with a water soluble dye added to the poly since your spraying. You ll have to experiment but it s a great way to warm up water white poly.
- Scott C.
I’ve experimented with dye in the poly a bit, but I was thinking that the shellac might give it a bit richer color.
View JimYoung's profile
JimYoung
294 posts in 1704 days
#8 posted 03-17-2016 04:21 PM
I’d be interested in knowing what you settled on. Also, what are you using to spray the poly, HVLP?
Thanks,
-- -Jim, "Nothing says poor craftsmanship more than wrinkles in your duck tape"
View Drew's profile
Drew
350 posts in 3217 days
#9 posted 03-17-2016 05:42 PM
Here are some samples I made a few years ago that might help.
Left to right.
Straight Arm R Seal
Danish oil with Arm R Seal top coat (tried and true Danish oil)
Straight waterborne poly with UV ( I believe it was Enduro poly)
Custom color- GF WB dye stains, 2pt Vintage cherry, 1pt Light brown. Enduro poly top coat
-- TruCraftFurniture.com
View bbasiaga's profile
bbasiaga
1240 posts in 2112 days
#10 posted 03-17-2016 06:07 PM
I was going to suggest natural color danish oil. It brings the pink raw cherry to a light reddish brown. Let it dry 3 days, the water born over the top.
Brian
View ClammyBallz's profile
ClammyBallz
442 posts in 1254 days
#11 posted 03-17-2016 06:32 PM
This cherry cabinet was finished with two coats of garnet shellac and then 2 coats of EM8000.
CharlesA
#12 posted 03-17-2016 07:21 PM
I’m on the road, so I don’t have a pic, but I did a sample board the other day, and I think I’m going to do one coat of sealcoat/super blonde with 3 coats of garnet shellac and then the waterborne poly, all sprayed.
View OSU55's profile
OSU55
1833 posts in 2107 days
#13 posted 03-18-2016 12:04 PM
For color only, adding dye (Trantint honey amber matches ob poly well) to the WB poly will do it, but the finish will be a bit lifeless. Shellac first will pop the grain like ob finishes, giving it some chatoyance – almost looks like a metallic paint in the light.
Sealcoat sometimes doesn’t play well with wb topcoats, so I always use flakes with them. I use blonde shellac and use Transtint to get whatever color I’m after. Don’t have to buy or inventory different colors of shellac.
