Dust Collector Room/Box
Forum topic by JenWoodworking posted 03-01-2010 08:45 AM 1916 views 0 times favorited 2 replies Add to Favorites Watch
View JenWoodworking's profile
JenWoodworking
128 posts in 3040 days
03-01-2010 08:45 AM
Topic tags/keywords: question dust dust collection dust collector box dust collector room dust collection room dust collection box tip advice dust advice dust question
I want to build a small box that is only slightly larger than my dust collector; insulated, outside, and heated with a light bulb(father-in-laws suggestion)
Anyone done this?
Answers I need/problems I have to address;
-fresh air exchange(gas furnace)
-must be heated as it freezes hard here often (can be weeks at -40C or lower!)
-exhaust was thinking that maybe I could run a “fine” filtered vent back into the building using (not sure what it is called for real but they’re blue scratchy-threads of plastic we use at home and easily wash) re-usable furnace filters cut to sized and layered maybe 3 or 4 thick
Know of any good web sites on dust collection technicalities such as these, or already have the answer I offer you thanks in advance for any info.
Thank-you, Jen
-- Jen loves wood!
2 replies so far
TopamaxSurvivor
18250 posts in 3645 days
#1 posted 03-01-2010 09:56 AM
Sounds like the exhaust system needs to be set up with a supply air duct with filtering in it back into the building. Look at air handler designs for commercial buildings to get an idea of what I’m saying.
View Dez's profile
Dez
1166 posts in 4047 days
#2 posted 03-01-2010 10:06 AM
Jen
You should have a fresh air intake for the furnace anyway if the building is anything close to airtight.
Rigid foam makes good insulated panels for walls glued to ply or OSB with “studs” at the edges.
Return air filters are a very good idea. (For the air returning to the shop from the dust collector “box”. There are a wide range of filters available, from furnace to paint booth intake filters.
Don’t know of any sites off the top of my head but I will speak up if I find any.
-- Folly ever comes cloaked in opportunity!
