Has anybody used "Glue Dots"?
Forum topic by jasoncarpentry posted 03-10-2016 08:12 PM 876 views 0 times favorited 9 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
142 posts in 2652 days
03-10-2016 08:12 PM
For my cutting boards, I usually attach semi-transparent rubber “feet” on the bottoms so they won’t slip on countertops or end up in a puddle of God knows what. I’ve been using the self-adhesive kind from Ace Hardware, but after a while they come off. So I need a stronger way of attaching these. I could use (and have used) small screws, usually stainless steel. I countersink these to avoid scratching countertops, etc.
Before I standardize on screws, however, I’d like to know if there’s an adhesive I can use (in addition to the self-adhesive mentioned above) to make a stronger bond. How about contact cement? “Gorilla Glue”? In addition, I just ran across a product at Home Depot called “Glue Dots.” Hey, they’re “Advanced Strength”! But it seems that all glue manufacturers claim their products are so strong that they’ll reinforce the Hoover Dam.
So has anybody used Glue Dots? If so, in what application(s)?
-- Jim in Tennessee
9 replies so far
View mds2's profile
mds2
310 posts in 1942 days
#1 posted 03-10-2016 08:15 PM
A drop of epoxy would probably keep them on forever. My wife use gluedots for scrapbooking. I dont know if they would hold more than 2 pieces of paper together.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2367 days
#2 posted 03-10-2016 08:28 PM
Don’t know if this interests you, but I’ve been using these on my cutting boards. $2.99 for 8, so $1.50/board.
I drill 4 holes in the underside of the board, put some clear 5-minute epoxy in the holes, and press the bumpers in (the hole is sized so it fits pretty snug). I’ve never had any issues. I like them because I don’t have to worry about them coming out, and they give enough clearance over the countertop (1/8”) that keeps the board from sitting in any water or whatever might be on the counter.
jasoncarpentry
#3 posted 03-11-2016 12:37 AM
Thanks for your feedback, mds2 and BinghamtonEd! I should have checked Rockler first, since I’ve never been disappointed in their products. A followup question for both of you: Rockler has several kinds of epoxies, both 2-part and other. Is there a particular kind of epoxy you recommend?
-- Jim in Tennessee
View splintergroup's profile
splintergroup
2011 posts in 1220 days
#4 posted 03-11-2016 03:03 PM
An alternative is to use old-school water faucet rubber valve washers.
The rubber is generally very hard and durable and some have a counter sunk recess for a screw.
I use these by drilling a shallow (1/8”) flat bottom recess the same diameter as the washer. I then use a stainless steel screw to attach the washer. They last forever and are inexpensive.
View Ghidrah's profile
Ghidrah
667 posts in 1219 days
#5 posted 03-12-2016 01:35 AM
All the cutting boards I’ve made are work ready both sides, if your issue is slippage then consider a camp or dry dish towel under it, slippage gone.
-- I meant to do that!
BinghamtonEd
#6 posted 03-12-2016 02:15 AM
For epoxy, I just use the clear-drying $5 two-part 5-minute all Loctite epoxy from Lowes. You can do a lot of boards with one pack.
View realcowtown_eric's profile
realcowtown_eric
608 posts in 1934 days
#7 posted 03-12-2016 02:21 AM
I also use the faucet washers….cheap and effective
Eric
-- Real_cowtown_eric
View DIYaholic's profile
DIYaholic
19620 posts in 2672 days
#8 posted 03-12-2016 03:37 AM
I use wine corks, epoxied into a recess….
View conifur's profile
conifur
955 posts in 1149 days
#9 posted 03-12-2016 03:53 AM
Heck why bother the top surface is going to get junk on it when using and cleaned, if you want to use both sides
just clean the bottom as you do the top. I do alot of cooking, and my counter is not full of gunk, if some one has a counter like that, it wont make a difference, they will have a cutting board top in the same condition. Plus what ever you would use, if you dont get them alll the same the board is not going to lay flat and rock when using. Annoying!!!
