How to secure threaded brass rod
« back to Joinery forum
Forum topic by kmetzger posted 03-10-2016 05:32 PM 940 views 0 times favorited 7 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1815 days
03-10-2016 05:32 PM
I’ve decided to try my hand at reproducing this music stand:
http://mydadsfurnitureblog.blogspot.mx/2012/11/cello-music-stand.html
The hardest part will be steam bending the two uprights. But I’m also ordering the hardware and am trying to figure out how to attach the two arms shown in the third photo from the top. I’m thinking of using 1/8” brass rod threaded on one end. But how to secure them? I can’t find 1/8” dowel inserts or cap nuts.
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
7 replies so far
View rwe2156's profile
rwe2156
2925 posts in 1477 days
#1 posted 03-10-2016 05:46 PM
Wow I am planning to build the same one for my son and have been thinking about the same question.
I think it is bigger than 1/8” I would say 1/4.
How about a threaded insert like this:
Hard to explain but I think a little dowel or mortise would hold the arms, while the rod would be screwed into the piece holding the threaded insert.
I want to make mine able to take it apart for transport. I’m thinking a little knurled knob either threaded on or soldered onto end of the brass rods would enable to unscrew by hand.
Good luck. I hope you will post your progress on this project!
View HokieKen's profile
HokieKen
4989 posts in 1135 days
#2 posted 03-10-2016 05:47 PM
You could insert the end of the rod through a dowel and peen the end so it’s free to rotate but won’t come out. Then epoxy/glue the dowel into the hole in the stand. You wouldn’t need it threaded that way.
-- Kenny, SW VA, Go Hokies!!!
View ddockstader's profile
ddockstader
155 posts in 3258 days
#3 posted 03-10-2016 05:51 PM
If your heart is not set on 1/8” brass rod, you can get all kinds of brass cap nuts from McMaster-Carr. But 1/8” translates into a #5 rod which is one size McMaster-Carr doesn’t have. But they have just about every other size.
kmetzger
#4 posted 03-11-2016 12:28 AM
Thanks for your ideas. I’ll work on a good solution. rwe: I hope we can exchange notes on how to do the whole thing, especially the steam bending.
rwe2156
#5 posted 03-12-2016 02:32 PM
Even though I’ve never done any it looks pretty straightfoward.
You have to make a pattern to clamp against and do some testing.
If I made one, I would either make a box or use a big pipe with a wallpaper steamer attached.
Lots of Youtube videos on this.
Good luck I will be a little while before I can start as I have one big workbench project I am finishing, and another I need to finish.
kmetzger
#6 posted 03-12-2016 02:48 PM
rwe2156
#7 posted 03-23-2016 10:53 AM
Kim, if you can’t get the steamer, you might consider a glued up lamination using thin strips.
