Sharpening a midi hollow master
Forum topic by TurnTurnTurn posted 02-28-2010 03:35 PM 1442 views 0 times favorited 2 replies Add to Favorites Watch
View TurnTurnTurn's profile
TurnTurnTurn
614 posts in 3345 days
02-28-2010 03:35 PM
Topic tags/keywords: question lathe sharpening
I recently purchased a Sorby Midi Hollow Master turning tool and it worked great until it needed sharpening. I have had little success sharpening the hollowing tip with a flat sharpening stone. I have tried various stone grades, but have not been able to get the tip anywhere near as sharp as it was right out of the box. Any suggestions?
-- TurnTurnTurn
2 replies so far
View Andrew's profile
Andrew
709 posts in 3434 days
#1 posted 02-28-2010 05:21 PM
They say to just flatten it, but if you can create a little burr on it it will work very well, it is small and hard to get a good enough hold on to burnish a burr. But if you can you will be happy you did.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
TurnTurnTurn
#2 posted 03-01-2010 02:31 AM
Andrew, thanks for the info, that definitely made a difference
-- TurnTurnTurn
