Hi,
I am a new woodworker and my first project (after building a workbench) will be a cabinet to hold my guns. My plan is to use 3/4 birch plywood. I designed the whole thing in sketchup and the approximate dimensions will be 15×20x60.
My main concern is to make sure the joints that I plan to make are strong enough. Here are few pictures showing how I planed to join the sides/back/shelves.
I plan to use a router to cut all dados.
Do you think this joint will be strong enough?
Thank you all
Thank you all
