| Forum topic by Jim K | posted 1180 days ago | 557 views | 0 times favorited | 7 replies | ![]() |
1180 days ago |
Hi All I’m trying to build two doors the span is 25 5/8. The mid point is 12 13/16? Second question in the center I want to use 1/4” Luan ply. How deep should the groove in my rail and style be so the ply can float in the center? I hope this makes sense to anybody? Not sure on this first big project? Jim K. |
7 replies so far
#1 posted 1180 days ago |
I’m no cabinet maker, but 4” stiles on a 12” door are going to look way out of proportion. Something in the 2 1/2 range would look a lot better. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#2 posted 1179 days ago |
Door size will depend on overlay vs inset. The cabinets I build are faceframes and my doors are 1/2” overlay. The math on that opening for width would be. [(25 5/8 + 1) – 1/8] X 1/2 = 13 1/4 ” doors. This factors in the 1/2 overlay and 1/8” space between the doors. Rails and stiles usually are a constant width and I most often make them 2 1/2” with a 7/16” groove. My panel math looks like this given 13 1/4 wide door. 13 1/4 – (2 1/2 + 2 1/2) + (7/16 + 7/16) = 9 1/8 ” panel. Substitute your number accordingly, but as Topamx said wide staile will look funny on narrow doors. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#3 posted 1179 days ago |
Thanks I’m going with 2” stiles and rails Jim K |
#4 posted 1179 days ago |
Someone taught me, years ago, to make the bottom rail wider. It has to do with eye appeal I guess. no one has ever commented on it and I like the effect. On most cabinets I have used 2 inch rails and styles on inset doors and 2 1/2 inch on over lay doors. The bottom rail is 3 inches and 3 1/2 respectively. The rail and stile cutters I used all cut a 3/8 deep by 1/4 groove for the panel. For plywood panels, I cut the panel really close to actual size and then dry fit to get it prefect. On solid wood panels I cut at least 1/16th smaller and in wet climates it’s best to allow 1/8. If you will check my projects and look at “The kitchen at 404 Blackaby Street”, you will see several doors in the size range you describe. -- Thos. Angle, Jordan Valley, Oregon |
#5 posted 1179 days ago |
Just double check to make sure your stiles are wide enough to fit your hinges. I learned this the hard way, and you can see it on one of my projects posted here. See if you can spot it! -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#6 posted 1179 days ago |
Maybe I should have stated before the doors are 72” tall. Jim K. |
#7 posted 1179 days ago |
If you haven’t already cut them, consider this. The hinge side needs more strength on the rails. It is also nice visually on a double door to make the whole of both doors look balanced when they are closed. This makes the center edge rail 1/2 or close to the the thickness of the hinge rail. But, strength is also a consideration. 2 3/4 ” hinge rails and 1 1/2” edge rails will give a more balanced look when closed. Also, leave at least 1/8” clearance on the hinge sides and the center (so subtract 3/8” form total width of both doors, making each door 12 5/8” wide). If you want the doors to touch on the inside edge when closed, bevel them back about 3 degrees toward the inside on the mating edge. Otherwise the inside edge may catch before they are fully closed (depends on how square and straight the casing is if it is a closet, and if you inset the hinges or not. Closet casings are rarely straight top to bottom, so find the minimum width to base your dimensions on. Planing a bevel on the inside edge is something you can do when fitting and hanging the doors). I am assuming this is a closet or cabinet. Entry doors have thicker stiles for the center (where the knob is) and the bottom (where feet are used to assist) than at the top. That is where the main stress comes when opening or closing. Wider width on the center and bottom also assist in the end glue joint to support the outer rail from sagging, where the top is not a big player. On a narrow door like this, stiles the width of the hinge stile will probably be okay, but you may consider upping then to 4” or at least the width of your stock wood cleaned up. Best to draw out a scaled drawing to get an idea of how the dimensions look to you. JTCW Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6160 |
