What do I need for a Bosch 1617EVSPK router to work with a PC Dovetail Jig
Forum topic by Konomigon posted 02-28-2010 06:40 AM 4884 views 0 times favorited 5 replies Add to Favorites Watch
View Konomigon's profile
Konomigon
55 posts in 3346 days
02-28-2010 06:40 AM
Topic tags/keywords: question jig router
Hi,
I own a Bosch router model 1617EVSPK and I’m think about picking up a Porter Cable dovetail Jig. I have reviewed the jig’s manual and it says that I need a router that accepts the template guides supplied with the jig. Does anyone using a setup like this? Does anyone know if I need to get anything for the router to use this jig?
Thanks!
-- Kris
5 replies so far
View Edziu's profile
Edziu
151 posts in 3171 days
#1 posted 02-28-2010 07:13 AM
Hello! Rockler offers a product called ””One Plate””:http://www.rockler.com/product.cfm?page=19741&filter=one%20plate It’s quite nice and comes set up for accepting template guides.
About the dovetail jig- Have you ever considered the Rockler Dovetail Jig? The jig is easier to set up and has more available accessories, like if you want to change dovetail spacing, or do miniature dovetails. It also uses the same template guides, so the Rockler One plate is still required. Just a thought.
View Sawdust4Blood's profile
Sawdust4Blood
408 posts in 3141 days
#2 posted 02-28-2010 09:26 PM
I’ve had the PC dovetailing jig for about 3 years and am happy with it. It ain’t foolproof but it ain’t rocket science either and produces good results. Last year I built a bedroom set with all the drawers dovetailed and it was pretty easy to do. I have a PC895 router which came with a base that was obviously compatible with PC template guides. I think that you may need the Bosch RA1100 adapter (if you want to stick to the Bosch base plate or you can use a universal base plate as suggested above) to use your Bosch router with the PC style guide that comes with the jig. My recollection is that the jig came with everything else you would need to operate except a centering pin. With any jig that uses the template guides, if everything isn’t centered exactly, you’ll get some error in the end.
-- Greg, Severn MD
Konomigon
#3 posted 03-01-2010 03:54 AM
Thanks for the great info!
-- Kris
Edziu
#4 posted 03-01-2010 04:24 AM
Good note about the centering pin- very crucial no matter what base you get!
View bigike's profile
bigike
4054 posts in 3408 days
#5 posted 03-01-2010 05:11 AM
you can make your own base plate from acrylic or polycarb very easy. I have quite a few (base plates) for about every router i have.
