Box top (made by Troy) question
Forum topic by TurdFerguson posted 02-27-2010 08:02 PM 1115 views 0 times favorited 11 replies Add to Favorites Watch
View TurdFerguson's profile
TurdFerguson
20 posts in 3058 days
02-27-2010 08:02 PM
Hey guys, first off, I just wanted to say thanks for all the ‘welcomes.’ This is my first (hopefully of many) post.
I wish I would have found this site before I bought all my tools. The reviews are really helpful. Unfortunately, I made the mistake of buying a Craftsman benchtop TS. I feel that thing is holding me back. But I have it and I’ll have to make it work for now.
Anyways, on to my question…
I was looking through the projects and saw this box that Troy made. And I’m curious as to how you would go about making the angles in the box top?
I was thinking of ripping a 45 degree angle in a 2×4 and then resting my work piece on that and set my blade to the desired angle, but I’m not sure if there’s a better way to do it.
Could someone shed any light for me? Thanks!
11 replies so far
View Waldschrat's profile
Waldschrat
505 posts in 3461 days
#1 posted 02-27-2010 08:23 PM
I would just use a hand plane and plane it down until you are satisified with the results… takes a bit of practice, but I would wager its definetly quicker and safer than having to build a jig, test the jig, then cut the box top to the angle required, thenhave to sand it anyway because the blade leaves the surface a bit rough.
Thats what I would do. I guess it all depends how comfortable you are with a hand plane.
-- Nicholas, Cabinet/Furniture Maker, Blue Hill, Maine
View bigike's profile
bigike
4052 posts in 3314 days
#2 posted 02-27-2010 08:30 PM
sounds good u can also use the fence too but the 2×4 makes it safer. i did the same thing buying a TS from sears craftsman too with the cast aluminum top and 11/16 wide miter slots and the fence was bowed but my stock still came out straight somehow but the cuts were not clean at all from there i got a delta unisaw with biesmyer fence and 52” of cut on the right side of the blade and it’s all good from there.
You have to make shure the angle that u cut at the blade still hits at the top right or left corner of the blade so u get that raised square on the top like the one in the pic, if u want that shape on yours.
View Hallmark's profile
Hallmark
432 posts in 3131 days
#3 posted 02-27-2010 08:33 PM
It looks like the flat side was against the table saw fence. Make a jig with that runs on the top of the fence which holds the piece againt the fence and has a stop, pick an angle you like and run it through on each end.
-- Style is simple, but not my execution of it.
TurdFerguson
#4 posted 02-27-2010 08:36 PM
Cool thanks for the quick replies.
Waldschrat, I haven’t gotten any planes yet. I’m still trying to decide which kind/brand to get. I’m on a college students budget.
Waldschrat
#5 posted 02-27-2010 11:27 PM
I know how that is… good luck finding some, or the one that suits you best!
View Chris Wright's profile
Chris Wright
540 posts in 3506 days
#6 posted 02-27-2010 11:52 PM
For hand planes, the best place to look are flea markets and yard sales. You can some times find old Record or Stanley for a good price that only need a little bit of TLC to bring them back to their former glory. Also eBay and Craigs List some times have some for a good price. If you want to go buy new ones, Lie Nielson/Veritas are some of the best, but you’ll also pay through the nose to get them. I’ve read good things about Gröz, and they cost a lot less. If you’re feeling up to it, you can always make your own. I’ve made a few and they are fun projects.
-- "At its best, life is completely unpredictable." - Christopher Walken
Chris Wright
#7 posted 02-28-2010 05:53 AM
This also could have been done with a panel cutting bit on a router or shaper.
35125 posts in 4426 days
#8 posted 02-28-2010 05:57 AM
Some tenon jigs allow you to hold wood at an angle. It might be able to do the holding.
View Gary's profile
Gary
9333 posts in 3458 days
#9 posted 02-28-2010 06:08 AM
Which ever way you end up using, be sure to keep safety in mind. I’m still typing slow from my fight with the table saw blade…...
TurdFerguson
#10 posted 02-28-2010 06:24 PM
Thanks for the help guys. Really appreciated. And Gary, I know what you mean. I had an accident while working on a house about 5 years ago and I think ever since then using a TS, I’ve always been as careful as possible.
Going back to planes, I see Rockler has the Groz block plane for $28. Would the Anant be any better? I’ve been looking on eBay for an old Stanley as well, but haven’t seen any that look worth it so far.
View webwood's profile
webwood
626 posts in 3275 days
#11 posted 02-28-2010 07:55 PM
i clamp these to a larger board and feed them through with the fence to the left of the blade (right tilt) – blade tilt about 15 degrees i think
-- -erik & christy-
