Sanding question
Forum topic by Tom posted 03-08-2016 04:38 AM 728 views 0 times favorited 9 replies Add to Favorites Watch
View Tom's profile
Tom
174 posts in 1025 days
03-08-2016 04:38 AM
I made a few cutting boards, sanded them down to 220 and they were super smooth. I put some mineral oil on them, let it soak then wiped off the excess. I then put a coat of beeswax/mineral oil on them. For some reason some of the boards you can now feel the seams on one side. I’m not sure what caused this…and will re-sand. I did wipe them down with a cloth but it wasn’t damp. Should I have used a damp cloth to get the sanding dust off then did a 2nd round with the 220? I’ve done that on some pine stuff I made and it seemed to raise the grain so it could be sanded off and they stayed smooth. Is this the sanding process I should be using with my boards?
9 replies so far
View McFly's profile
McFly
273 posts in 992 days
#1 posted 03-08-2016 05:03 AM
I’m assuming you’re using multiple species in strips for your boards. Different species have different densities, so they may sand differently.
I’m curious about the damp towel wipe down to raise the grain myself. Always looking to find a new & improved method.
View Tom's profile
Tom
#2 posted 03-08-2016 01:19 PM
I got this from the can of sanding sealer I was using. It said to wipe the wood with a damp cloth then put on sanding sealer. Sand after dry then put on poly. Worked pretty well on pine but I didn’t think hardwoods would have the same issue since I just started working with them. The only good think is that the “bottom” of the board is where the issue is, not the top.
View TechTeacher04's profile
TechTeacher04
371 posts in 1496 days
#3 posted 03-08-2016 02:13 PM
McFly is right the mineral oil soaked in and swelled the wood, even if the species was the same the density will vary depending on growth ring shape and size.
View KYSean's profile
KYSean
119 posts in 3561 days
#4 posted 03-08-2016 02:31 PM
How is the oil going to absorb into the wood if you use sanding sealer?
-- http://editedwrite.com
View moke's profile
moke
1154 posts in 2741 days
#5 posted 03-08-2016 05:44 PM
+1 with KYSean…..I don’t think I would use sanding sealer….now that is not your issue with the seam, but sanding sealer will fill in the pores of the wood and not allow the mineral oil to penetrate or at least it will be inhibited
Just my .02
Mike
-- Mike
View Tom's profile
Tom
#6 posted 03-08-2016 05:49 PM
Let me clarify…I didn’t use sanding sealer on my cutting boards…it was on some small boxes that I made previously. The only finish I’m using on my cutting boards is mineral oil and beeswax. I’m going to re-sand the bumpy sides and re-oil them. The next time I do cutting boards I’ll try uisng a damp cloth to wipe the dust off then re-sand if needed.
View oldwood's profile
oldwood
133 posts in 1209 days
#7 posted 03-09-2016 04:21 AM
The grain raising is a very important step but is not the cause of your problem. I use a wet rag with just a quick wipe over all surfaces. Let dry completely before sanding.
View Andre's profile
Andre
1785 posts in 1771 days
#8 posted 03-09-2016 05:04 AM
I would use a card scraper for the final finish, skip the sandpaper if you want a real smooth finish.
View Snipes's profile
Snipes
173 posts in 2209 days
#9 posted 03-09-2016 02:20 PM
I think what your talking about is what many call creep (glue creep). google it lots of info. I think if you let it dry longer after gluing before final sanding it will take care of most issues.
-- if it is to be it is up to me
