10 inch FTG Table Saw Blade
Forum topic by bwanamdogo posted 03-08-2016 12:56 AM 2511 views 0 times favorited 12 replies Add to Favorites Watch
View bwanamdogo's profile
bwanamdogo
15 posts in 1926 days
03-08-2016 12:56 AM
I have been trying to find a table saw blade to cut finger joints and need a 10 inch blade with .125 kerf with an FTG. Having no luck.
-- Bwanamdogo
12 replies so far
View amt's profile
amt
49 posts in 1838 days
#1 posted 03-08-2016 01:01 AM
View jusfine's profile
jusfine
2422 posts in 3046 days
#2 posted 03-08-2016 01:04 AM
I was also looking quite awhile ago, couldn’t find what I wanted in anything other than a 24 tooth rip blade – not the best if you want a really flat surface.
Good luck!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View lateralus819's profile
lateralus819
2241 posts in 2009 days
#3 posted 03-08-2016 01:09 AM
http://www.amazon.com/Freud-LM72M010-Industrial-10-Inch-8-Inch/dp/B00004T78V/ref=sr_1_3?ie=UTF8&qid=1457399277&sr=8-3&keywords=Freud+ice+coating
I’m on my 2nd (Still have to send the first out for sharpening)
These things are incredible for the price. They cut extremely well, leave a perfectly flat bottom and they seem to last forever in terms of sharpness.
After many hours of use, I don’t see me switching to another blade.
View bondogaposis's profile
bondogaposis
4929 posts in 2471 days
#4 posted 03-08-2016 01:43 AM
Here’s one LM72R010.
-- Bondo Gaposis
View knotscott's profile
knotscott
8122 posts in 3495 days
#5 posted 03-08-2016 02:00 AM
Lots of options – Infinity 010-024, CMT 201.024.10, Freud LM72, Amana Tool 610240, Delta 35-611, Tenryu RS-25524CBN
View amt's profile
amt
#6 posted 03-08-2016 05:06 AM
There’s also the Ridge Carbide TS2000, which is a combo blade with every 5th tooth having a FTG. I use that as my every day blade, and quickly becoming my never change out blade, because it seems to do everything really well.
-- -Andrew
View DirtyMike's profile
DirtyMike
637 posts in 1022 days
#7 posted 03-08-2016 05:17 AM
i highly recommend the lm72 for single blade box joints and its great for ripping. also a combo blade with some flat teeth wont give you the cut you want, the atb teeth are wider than the ftg teeth. good luck
knotscott
#8 posted 03-08-2016 10:26 AM
There s also the Ridge Carbide TS2000, which is a combo blade with every 5th tooth having a FTG. I use that as my every day blade, and quickly becoming my never change out blade, because it seems to do everything really well.
- amt
The TS2000 is an ATB/R design. It does have some FTG teeth, but the ATB teeth protrude slightly above it to reduce tearout on cross grain cuts. The end result is that it doesn’t leave a truly flat bottom.
View geekwoodworker's profile
geekwoodworker
378 posts in 1580 days
#9 posted 03-08-2016 02:10 PM
View HokieKen's profile
HokieKen
6174 posts in 1258 days
#10 posted 03-08-2016 03:08 PM
Here is a Freud that is a 60 tooth TCG combination blade. The extra teeth should give you a cleaner cut and it’s pretty doggone cheap for a Freud Industrial blade!
-- Kenny, SW VA, Go Hokies!!!
View Woodknack's profile
Woodknack
12338 posts in 2500 days
#11 posted 03-08-2016 06:14 PM
<blockquote>
Leevalley sells one specifically for this. http://www.leevalley.com/en/Wood/page.aspx?p=59404&cat=1,41080,41165&ap=1
- geekwoodworker
</blockquote>
I believe the carbides are offset to make the two sizes so the blades can’t be used for a 1/8” cut.
View xeddog's profile
xeddog
200 posts in 3127 days
#12 posted 03-08-2016 07:10 PM
Several years ago I was at a woodworking show and Forrest was there. The company, not the dude. Anyway, I bought a blade which was essentially a WWII but had a custom #1 grind. If I remember correctly, it was just a WWII that had the devil ears ground flat to produce a flat bottomed kerf. That was before they had special box joint blades, or blade sets.
Wayne
