Glue removal from sanding belts
Forum topic by Nostradamit posted 03-07-2016 02:05 PM 815 views 0 times favorited 7 replies Add to Favorites Watch
View Nostradamit's profile
Nostradamit
41 posts in 1043 days
03-07-2016 02:05 PM
Topic tags/keywords: resource
While cleaning up some dried latex paint on my shop floor with a product called “GOOF OFF” I noticed that a glob of dried wood glue melted when it came it contact with the liquid. I thought of the glue streaks on my performax sanding belt and wandered if it would remove the glue build up. I dabbed a small amount with a small paint brush and let it set for a few minutes. I brushed it off with a small brass brush and sure enough the glue disappeared. It left no residue and did not have any effect on the sanding belt.
7 replies so far
View splintergroup's profile
splintergroup
2437 posts in 1428 days
#1 posted 03-07-2016 05:36 PM
Yes, this is a good way to restore glue-fouled sander belts.
Personally I use a bucket filled with ammonia or Simple Green. Let it soak then brush away the gunk.
View BurlyBob's profile
BurlyBob
5987 posts in 2471 days
#2 posted 03-07-2016 06:17 PM
Thanks for the it. I sure it’s going to come in very handy.
View bigblockyeti's profile
bigblockyeti
5290 posts in 1927 days
#3 posted 03-07-2016 08:31 PM
Goof Off is a pretty powerful (and volatile) solvent. It’s fairly similar to lacquer thinner if you’re doing something where you need alot of it, if you do, you’ll need good ventilation as well.
Nostradamit
#4 posted 03-07-2016 11:50 PM
Goof Off is a pretty powerful (and volatile) solvent. It s fairly similar to lacquer thinner if you re doing something where you need alot of it, if you do, you ll need good ventilation as well.
- bigblockyeti
Thanks for mentioning that bigblockyeti as I forgot to. Yes indeed in is volatile so be sure to use with adequate ventilation and use nitrile gloves
View JBrow's profile
JBrow
1366 posts in 1126 days
#5 posted 03-08-2016 12:08 AM
Toolcollector
Thanks for the tip.
I change the paper on my drum sander mostly because of the little clumps of whatever, not because the paper has worn out. I am not sure that what I observe is from glue, but rather wood dust stuck to the paper by lignin from the wood. I can usually remove these clumps by prying at the clump with a small screw driver. That takes a lot of time and can damage the paper.
When I next service the drum sander, I will give this GOOF-OFF a try. But I will lay some plastic and then card board down on the conveyor belt to protect it.
View jeffwedekind's profile
jeffwedekind
144 posts in 2898 days
#6 posted 03-16-2016 11:46 PM
Here’s what I do
http://lumberjocks.com/reviews/3810
-- Jeff, eastern Wa
Nostradamit
#7 posted 03-17-2016 01:19 AM
