Glue Ups
« back to Joinery forum
Forum topic by invertMASA posted 03-07-2016 02:50 AM 645 views 0 times favorited 4 replies Add to Favorites Watch
View invertMASA's profile
invertMASA
9 posts in 729 days
03-07-2016 02:50 AM
Topic tags/keywords: jig question trick tip
So I made my first end grain cutting board and it looks alright. But being my first, not all the patterns line up. I had some problems during the second glue up. Things shifted a bit, then dried to much and could not fix them. What are the best ways to clamp them down? So things do not slide around so much.
Thanks
-- Looking for some pallet ideas? Check out this site http://thispallet.com/
View MadMark's profile
MadMark
979 posts in 1358 days
#1 posted 03-07-2016 02:57 AM
Glue up a slab of alternating woods in pairs. Once solid, make sure its flat and then crosscut into shorts. Fit into a glue corner and stack reversing every other one. This is the same tip for making chessboards.
M
View Lynchee's profile
Lynchee
18 posts in 1149 days
#2 posted 03-21-2016 03:26 AM
What are you using for clamps? Pipe or bar clamps are best (IMHO), then just get your pattern setup(on a pair of clamps), apply a clamp across the top and slowly apply pressure while maintaining the pattern. Then, just finish clamping.
invertMASA
9 posts in 729 days
#3 posted 03-21-2016 03:45 AM
That is what I am doing now, I have a work bench made so I can be fully prepared. Helps out a ton! and I have some of both. Second one looks much better!
And no that is not the glue I used to glue this up in the background.
View chiseler's profile
chiseler
124 posts in 793 days
#4 posted 03-21-2016 04:10 AM
I think you did a nice job
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
