Vibrating bandsaw help needed
Forum topic by Polishcannon posted 03-05-2016 11:30 PM 820 views 1 time favorited 12 replies Add to Favorites Watch
View Polishcannon's profile
Polishcannon
75 posts in 868 days
03-05-2016 11:30 PM
I am currently building a multipurpose shop table, its primary use will be as an outfeed table. I decided to build the frame with some 3×3 stock, and use mortise and tenon joinery. Today I pulled out my bandsaw for the first time. I have a 14” Rockwell with a riser block installed. I put a new 3/4” blade on it for making my shoulder cuts and some future re-sawing. I also installed a new tensioning spring before using. The blade seem to track well and it cut great, but there seem to be an excessive amount of vibration while cutting. The saw sits in a mobile base, and has an enclosed stand. I have had it for years but, this is the first time using it for a project. I am looking for help with eliminating some of the vibration and tuning the saw up.
12 replies so far
View NSBruce's profile
NSBruce
172 posts in 1098 days
#1 posted 03-05-2016 11:43 PM
You might try putting a bit more tension on your blade and alos check to see if your pulleys are runing square to each other( motor to blade)
Bruce
-- NSBruce
View MrUnix's profile
MrUnix
6695 posts in 2192 days
#2 posted 03-05-2016 11:50 PM
Sounds like you are trying to push that saw past it’s limits – a 3/4” blade is really pushing it, even without a riser.
Here is the obligatory band saw tune up video:
Band Saw Clinic with Alex Snodgrass
PS: On my 14” Delta, without a riser, 1/2” is about as wide as it can realistically handle – even though the manual states 3/4 is the max.
View Ripthorn's profile
Ripthorn
1458 posts in 2978 days
#3 posted 03-06-2016 12:07 AM
The most likely culprit is that the belt developed a set from not being used. Try a new belt. A link belt was the single biggest improvement to vibration control on my bandsaw when I was getting it up and going after sitting in a shed for many years.
Polishcannon
#4 posted 03-06-2016 01:45 AM
The saw cut the material like butter, so the belt comments sound more like the issue. I will check the belt tracking and get a segmented belt. Thanks for all the input.
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 922 days
#5 posted 03-06-2016 02:46 AM
- Polishcannon
When people say that 3/4 inch blades are too much, that’s in regards to tensioning and how much support the crown of the tire gives to the blade. Using a blade bigger than 1/2 inch puts alot of stress on the saw, and 3/4 inch blades require more tension than a typical 14 inch bandsaw can supply.
-- still trying to think of a clever signature......
Polishcannon
#6 posted 03-06-2016 03:18 AM
Regarding tensioning, I replace the original spring with an Iturra spring. This aftermarket spring allows for greater tension to be utilized. I agree factory springs do not allow for the necessary tension. Most are not even equal to half of what the blade scale reads or requires. As far as what the tires can handle, you may have a point. The vibration I experienced did seem to originate from the base of the saw. I appreciate your input and will try a smaller blade to test the hypothesis.
MrUnix
#7 posted 03-06-2016 03:23 AM
Unless your original spring was bottoming out, a replacement one will not do anything. The problem with trying to use a large blade is the amount of tension needed will cause more flex on the frame (and even worse with a riser), and will put too much force on the pivot bracket – causing it to eventually bend/deform/break. But if it works for you, go for it.
As for isolating the vibration, try first running without a blade. If you still have vibration, try running without the belt. You should be able to determine where the vibration is originating from.
Polishcannon
#8 posted 03-06-2016 03:40 AM
Ok. I will remove the blade and run the saw. Sound advice. Thanks for the info on large blades.
TheWoodRaccoon
#9 posted 03-06-2016 04:07 AM
- Polishcannon
Here’s a good way to isolate any vibration:
Run the motor by itself with the pulley removed from the motor’s shaft. If there’s no vibration, put the pulley on the motor and run it. If there’s no vibration, attach the drive belt (make sure both pulleys are perfectly aligned and square with each other.), then remove the lower wheel and run it. Those three steps will tell you if the motor and pulleys are balanced. If there’s still no vibration, re-attach the lower wheel and run it with no blade. That will tell you if the lower wheel is balanced. Then put on a small blade and run the saw. Then try it with a big blade.
This is what i did to test my saw! After all that, you should know what’s causing the vibration. Hope this helps!
Polishcannon
#10 posted 03-06-2016 04:22 AM
I watch the Snodgrass bandsaw video. It was great. Thank you.
Polishcannon
#11 posted 03-13-2016 07:45 PM
MrUnix & Woodracoon
I had some time today in the shop, and removed the 3/4” bandsaw blade. I ran the saw without any blade and the excessive vibration was gone. You guys were right about the blade issue. I will scale down to a 1/2” blade.
Thank you
Polishcannon
View toolie's profile
toolie
2121 posts in 2621 days
#12 posted 03-14-2016 07:48 PM
Do yourself a favor and get a Lennox blade from Iturra design. No one welds BS blades like Lou iturra. A similar blade took a POS 18” Jet BS from useless to useful. If your wheels are balanced, then a vibrstion problem will probably be blade based. Don’t waste time on those lousy timber wolf blades either. There’s a reason they run 4 for the price of three promotions, and it’s not because they are good guys or that their blades are superior products, IMHO.
