Saw inserts
Forum topic by MrRon posted 03-05-2016 05:22 PM 1045 views 0 times favorited 24 replies Add to Favorites Watch
View MrRon's profile
MrRon
4630 posts in 3148 days
03-05-2016 05:22 PM
I make my own table saw blade inserts. I make them flat from plywood, but after some time, the insert bows up in the middle leaving a raised insert. If I adjust it down, the leading and trailing edges are below the top of the table. My question is; what is the best material to make inserts from that will remain flat?
24 replies so far
View bearkatwood's profile
bearkatwood
1478 posts in 916 days
#1 posted 03-05-2016 05:28 PM
I made my insert from MDF and it has held up well so far.
You can read about it here
-- Brian Noel
View xeddog's profile
xeddog
177 posts in 2912 days
#2 posted 03-05-2016 05:36 PM
I have made some from some old discarded Corian counter top. They have held up VERY well and have remained flat.
Wayne
View unbob's profile
unbob
801 posts in 1808 days
#3 posted 03-05-2016 05:51 PM
Same problem as Ron, using the crappy birch or whatever plywood from HD. I use a block plane to get the lumps out. I need to find something better also.
4874 posts in 2398 days
#4 posted 03-05-2016 05:53 PM
I’ve used hard maple and had no problems.
View SuperCubber's profile
SuperCubber
1015 posts in 2189 days
#5 posted 03-05-2016 06:03 PM
I just made one from melamine, and it seems to be working well so far.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View Rick_M's profile
Rick_M
11101 posts in 2284 days
#6 posted 03-05-2016 06:20 PM
I use 1/2” MDF, never had one bow.
-- http://thewoodknack.blogspot.com/
View Lee's profile
100 posts in 782 days
#7 posted 03-05-2016 06:47 PM
I use 1/2” MDF or particle board then glue on a laminate top for smother sliding, never had one bow. Man made material is much more stable than plywood or lumber
-- Colombia Custom woodworking
View Jim Finn's profile
Jim Finn
2619 posts in 2826 days
#8 posted 03-05-2016 10:09 PM
I also use MDF for this.
View MadMark's profile
MadMark
979 posts in 1357 days
#9 posted 03-05-2016 10:32 PM
I bought a ZCI preformed from cast something like ebonite. Fits perfect & solid as a rock. Under $30 and I ordered it with the saw.
M
View jumbojack's profile
jumbojack
1673 posts in 2528 days
#10 posted 03-05-2016 10:34 PM
MDF is a perfect solution.
View MrUnix's profile
MrUnix
6346 posts in 2103 days
#11 posted 03-05-2016 10:35 PM
I’ve toyed around with the idea of making some out of HDPE… anyone ever tried? I’ve got some ‘plastic’ wood that I made from old grocery store bags, but it’s a little too thin (1/4”) for the TS, so I would need to make up some thicker stuff:
I make the inserts for my bandsaw and scroll saw out of the stuff, and it works great, even though those are only about 1/8” thick. I don’t see any reason why it wouldn’t work for the TS as well (using 1/2” thick material).
View knotscott's profile
knotscott
7872 posts in 3280 days
#12 posted 03-05-2016 10:45 PM
“Best” is always subjective, but it’s a really important component in the table saw chain. Inserts that flex, rock, or don’t sit flush can effect the quality and accuracy of the cut, which can work against hundreds (thousands) of dollars worth of machinery, blades, precision fence and miter gauges, jigs, setup components, and lumber.
Phenolic is one of the better materials for DIYers IMO. You can buy it in bulk pieces to make your own, or Leecraft is one of the better brands to buy premade inserts. It’s very flat, very stable, very strong, smooth, and machines quite well. Steel and other metals work well for manufacturers, but is much harder for DIYers to work with. MDF, ply, and hard woods are ok, but have the drawbacks of not being as strong, stable, smooth, or flat as phenolic. Any plastic inserts (HDPE, UHMW, acrylic, etc) that I’ve had have also been too weak and don’t stay as flat.
View joey502's profile
joey502
520 posts in 1422 days
#13 posted 03-05-2016 10:47 PM
I use UHMW for mine. I buy it in thicker pieces than i need then joint and plane it. There has not been any issues yet.
View bondogaposis's profile
bondogaposis
4599 posts in 2256 days
#14 posted 03-05-2016 11:04 PM
I use MDF sandwiched between layers of plastic laminate.
-- Bondo Gaposis
View Sany Ahmed's profile
Sany Ahmed
6 posts in 731 days
#15 posted 03-06-2016 10:43 PM
I made my own by hard maple and MDF. And I didn’t have any problem.
