Stopped rabbet in 1 1/2" round stock
Forum topic by ruco posted 03-05-2016 03:18 AM 645 views 0 times favorited 14 replies Add to Favorites Watch
View ruco's profile
ruco
22 posts in 842 days
03-05-2016 03:18 AM
Any idea on how to make this stopped rabbets in 1 1/2” round stock?
14 replies so far
View jbay's profile
jbay
2331 posts in 921 days
#1 posted 03-05-2016 03:39 AM
I don’t know what your making, but I would rabbet the whole dowel then glue in the pie cut pcs as needed.
View ruco's profile
ruco
#2 posted 03-05-2016 04:06 AM
Thank you jay,
I thought doing that, but the kerf width will take material and would´t look right,
View jbay's profile
jbay
#3 posted 03-05-2016 04:10 AM
Thank you jay,
- ruco
Well don’t use the same piece that you cut out. The pie piece has to come out of fresh dowel.
View ruco's profile
ruco
#4 posted 03-05-2016 04:20 AM
That´s a good idea,
but I´m still thinking how to do it with out cutting the whole length of the piece and then glueing the “pie” piece
thanks jbay!
View jbay's profile
jbay
#5 posted 03-05-2016 04:24 AM
View bandit571's profile
bandit571
20207 posts in 2705 days
#6 posted 03-05-2016 05:15 AM
Handsaw to make the start of the cuts. Chisel to chopped out the waste. Sholder plane to smooth things out.
Or
Set up a sled to hold the dowel securely in place, run the dowel over a mortising bit in a router table, the square the corners with a chisel
or
Start with a square piece of stock, chop out the waste, then turn the remaining piece on the lathe until round.
View TheFridge's profile
TheFridge
9603 posts in 1508 days
#7 posted 03-05-2016 05:33 AM
Router and sled then chisel the corners out?
Cutting a rabbet in square stock with a router plane and chisels then turning it down like bandit said would be my preferred way.
View Woodknack's profile
Woodknack
11763 posts in 2402 days
#8 posted 03-05-2016 06:32 PM
Depends on how many you need. For one I would make it by hand with saw and chisel. For ten I would make a router sled.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1050 posts in 1088 days
#9 posted 03-05-2016 06:38 PM
Make a cradle for the rod and place a template over it and use a router and then clean up with a chisel.
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View ruco's profile
ruco
#10 posted 03-05-2016 06:40 PM
I need 32 pieces of 8 ft. long with 4 stopped rabbets in each,
I like turtlecarpenter suggestion
TheTurtleCarpenter
#11 posted 03-05-2016 07:49 PM
Capture the rod between two 2×4s and tack a square 1 1/2” block to the end to keep the rod from rotating. Fasten one block down solid and take the other 2 by and fasten the template to it, locate the pattern and clamp it off, then use the router with a collet or freehand.
View bearkatwood's profile
bearkatwood
1592 posts in 1033 days
#12 posted 03-05-2016 08:10 PM
For me it would be as easy as locking it in my router mill, but if you hot glue a couple blocks on the ends you could use a router table and fence.
-- Brian Noel
View ruco's profile
ruco
#13 posted 03-05-2016 08:16 PM
Can you explain me a bit more bearkatwood?
I like your idea.
Thanks turtlecarpenter
View Firewood's profile
Firewood
340 posts in 1656 days
#14 posted 03-05-2016 08:46 PM
What if you start with square stock, cut the rabbets, then form the dowel with a roundover bit. When forming the dowel, leave a tail on each end to provide support for the next side’s cut.
-- Mike - Waukesha, WI
