Saw recommendation for cutting tenons
« back to Hand Tools forum
Forum topic by bbasiaga posted 03-05-2016 01:37 AM 872 views 0 times favorited 8 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1242 posts in 2230 days
03-05-2016 01:37 AM
I’m looking for a good starter saw for cutting tenons. I mainly work with 3/4” material, and in widths less than 4”. I see that Veritas has some carcass saws for $80 each. I was hoping to get in to something for less than that, and ideally something dual purpose enough to do the rip and crosscut parts of the tenon.
Any recommendations? I don’t want to jump in with $150 of stuff for something I’m not sure I’m going to do a lot, or like doing enough that I don’t revert back to power tools. Any decent starter saws out there that are decent multitaskers?
Thanks,
Brian
8 replies so far
View jmartel's profile
jmartel
8276 posts in 2385 days
#1 posted 03-05-2016 01:50 AM
You can always just buy a rip carcass saw and not the crosscut for now. Then you’re in for only $80. If you scribe your crosscut lines a bit more than normal, you shouldn’t have much trouble with tearout.
View eflanders's profile
eflanders
320 posts in 2085 days
#2 posted 03-05-2016 02:05 AM
You may want to try a Japanese saw in combination with a sharp chisel. Based on what you’ve said, this will fit your budget easily and with the material thicknesses and widths you have given.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#3 posted 03-05-2016 02:08 AM
This is what I have been using, although probably not what you were going for.
Sure cuts clean through tenons though.
View lepelerin's profile
lepelerin
495 posts in 2560 days
#4 posted 03-05-2016 02:24 AM
you could get something similar to this amazing Japanese saw.
http://www.amazon.com/Gyokucho-Double-Ryoba-RazorSaw-Woodworker/dp/B00BSQU9UQ
bbasiaga
#5 posted 03-05-2016 04:43 PM
Thanks. I was looking at those Japanese saws, but they have so many options I got confused. A little more research and it gets clearer. Seems like I’d need to go with one of their spined versions to make sure the cut didn’t drift too much to make a usable tenon without lots of cleanup. I’m not opposed to that. Seems like I might still be able to get a decent deal.
You can always just buy a rip carcass saw and not the crosscut for now. Then you re in for only $80. If you scribe your crosscut lines a bit more than normal, you shouldn t have much trouble with tearout.
- jmartel
I thought about this as well. I saw a couple of videos where guys scribed the cut line, then chiseled back to to it so the saw started down from the level of the finished shoulder. If that works reliably, it might be a good place to start with either a western or Japanese rip saw.
-Brian
View chrisstef's profile
chrisstef
17796 posts in 3241 days
#6 posted 03-05-2016 04:51 PM
Those veritas are good bang for your buck. Probably the best on the market for that money. Theyll cut 90% of your joinery. Dovetails, tenons, and paired with a bench hook, finish cuts.
View rwe2156's profile
rwe2156
3230 posts in 1715 days
#7 posted 03-06-2016 10:27 AM
You need a good quality tenon saw so you’ll have to bite the bullet. But you don’t need a $200 saw, based on the molded spine saw I already posses, I would expect the LV tenon saw to be of equal function.
The scoring method you describes is pretty standard technique in fine ww’ing. ;-) but you still need a Xcut saw IMO.
The Japanese saws are very very nice, but slightly diff techniques for use. Good ones not that cheap, either.
I think a carcase Xcut saw + a rip tenon saw would be a good combo.
View bearkatwood's profile
bearkatwood
1672 posts in 1246 days
#8 posted 03-06-2016 01:41 PM
You could get a good gent saw for pretty cheep and they work O.K. a Japanese pull saw would work as well, but you would miss out on the backsaw feel. You could find an oldy but a goodie at a thrift store and sharpen it up. If you are kinda handy you could make your own for cheaper that the Veritas, I think a 14” would run you around 50 for all the parts and then you make the handle. They are a lot of fun to build. If you are interested you can order the parts here at BlackBurn Tools
Hope that helped.
-- Brian Noel
