How is this made?
Forum topic by Jonathan posted 03-04-2016 11:37 PM 1122 views 0 times favorited 24 replies Add to Favorites Watch
View Jonathan's profile
Jonathan
25 posts in 1186 days
03-04-2016 11:37 PM
Topic tags/keywords: carving modern question trick tip resource
How is this “crater” made?
The diameters seem to be approximately 4 inches
24 replies so far
View No12's profile
No12
7 posts in 850 days
#1 posted 03-04-2016 11:47 PM
I did something similar by regrinding a paddle bit.
View MrUnix's profile
MrUnix
6188 posts in 2070 days
#2 posted 03-04-2016 11:52 PM
Cove bit in a plunge router (also known as a round nose bit).
View bobasaurus's profile
bobasaurus
3363 posts in 3055 days
#3 posted 03-04-2016 11:52 PM
Round cutter in a drill press, or a special router bit.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
Jonathan
#4 posted 03-05-2016 01:04 AM
Since the circle is probably more than 3 inches diameter, how does one make the crater with a smaller cove bit?
- MrUnix
View Ripthorn's profile
Ripthorn
1454 posts in 2856 days
#5 posted 03-05-2016 01:17 AM
Based on the above picture, it doesn’t look 3” in diameter, perhaps 2 to me. You can get very large cove bits. other ways to get it: CNC with a ball nose end mill, make your own cutter from steel rod, or spin the board relative to a circular saw blade with the center of the divot being the right over the top of the blade. That last suggestion is insanely dangerous, and I wouldn’t recommend it in any way, shape, or form.
MrUnix
#6 posted 03-05-2016 01:19 AM
Good question :) I’ve seen round nose bits up to 3 inches… can’t say I’ve seen them larger but they might be out there somewhere. Are you sure those divots are larger… kind of looks like 1x (1×6, 1×8 maybe) stock or thereabouts, so based on the scale compared to the board edge, they don’t look that large.
Jonathan
#7 posted 03-05-2016 01:44 AM
Thanks Brad :)
They are for dips. Guacamole and salsa for example. So the coves are 3” 3.5” or even 4”
View bigblockyeti's profile
bigblockyeti
4881 posts in 1592 days
#8 posted 03-05-2016 12:37 PM
I’m wondering if someone doesn’t make a bit just for this kind of application, something that certainly wouldn’t be spun as fast as a router and would require more torque, for use in a drill press for example. Below is a 2 3/4” rosette cutter designed to be used in a drill press and I would imagine it wouldn’t be too hard to get one made. It might be somewhat expensive for a custom grind from carbide, but tool steel wouldn’t be.
View Clarkie's profile
Clarkie
450 posts in 1712 days
#9 posted 03-05-2016 01:03 PM
You start out by placing the dip on the flat board and let the guests dig out the hole by their fondness for dip. Hey, I didn’t have another feasible answer..lol
bigblockyeti
#10 posted 03-05-2016 01:41 PM
^ Yeah but wouldn’t you have to serve them chips made from steel or carbide? Depending on how tasty the dip is, it might still work.
View gwilki's profile
gwilki
175 posts in 1345 days
#11 posted 03-05-2016 02:19 PM
I’ve done similar pieces on my lathe, using 3 or 4 different centers. It’s a bit scary having a propeller turning around, but the turning itself is quick and easy.
-- Grant Wilkinson, Ottawa ON
View Tony_S's profile
Tony_S
796 posts in 2954 days
#12 posted 03-05-2016 03:31 PM
Holy shat!
I’m in the wrong business! Cool idea…but…?
400.00 dollars for a piece of wood…?? I’m gonna be rich…
http://www.thewoodenpalate.com/products/small-dip
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Dark_Lightning's profile
Dark_Lightning
3020 posts in 2980 days
#13 posted 03-05-2016 04:28 PM
Wow! For that kind of scratch, the cost of the bit would easily be recouped.
-- Random Orbital Nailer
View bearkatwood's profile
bearkatwood
1449 posts in 883 days
#14 posted 03-05-2016 05:56 PM
Holy snap! That is a high mark-up.
-- Brian Noel
116804 posts in 3448 days
#15 posted 03-05-2016 06:39 PM
you could try something like this but in your case you would have to make a jig to let a circular saw turn in circles on top of you wood ,sounds crazy but so does turning a bowl on a table saw.
https://www.youtube.com/watch?v=uv3IxAgCS2c
