Drum sander
Forum topic by Woodcut1 posted 03-04-2016 05:05 PM 1291 views 0 times favorited 17 replies Add to Favorites Watch
View Woodcut1's profile
Woodcut1
34 posts in 943 days
03-04-2016 05:05 PM
Any advice on what is the best drum sander to buy. I will be sanding laminated bench tops, table top and smaller things.
17 replies so far
5069 posts in 2613 days
#1 posted 03-04-2016 05:26 PM
I would personally choose an open frame (C frame) design, and it would be a Supermax 19/38, or one of it’s cousins.
View moke's profile
moke
1229 posts in 2896 days
#2 posted 03-04-2016 05:46 PM
+1 with Fred
-- Mike
View weldoman's profile
weldoman
114 posts in 2177 days
#3 posted 03-04-2016 11:18 PM
I’m in the market also, just wondering why you guys would choose the open frame instead of the closed like the woodmaster?
-- missouri, dave
View RogR's profile
RogR
111 posts in 984 days
#4 posted 03-05-2016 02:10 AM
I m in the market also, just wondering why you guys would choose the open frame instead of the closed like the woodmaster?
The obvious advantage of the open end is the capacity to sand an item wider than the drum.
View JBrow's profile
JBrow
1366 posts in 1039 days
#5 posted 03-05-2016 02:33 AM
Woodcut1,
Since I have never used an open frame drum sander, I cannot comment concerning the performance of this type of machine. However, one question has occurred to me regarding the open frame design. That is when sanding a panel wider than the width of the drum, does the panel come out of the sander flush across its width. From what I gather from those who post regarding open frame sanders, this is not a problem. However, sanding a panel wider than the drum capacity requires twice the time to flush up the panel as would be required by a closed frame sander of sufficient capacity.
I purchased a closed frame Woodmaster 38” closed frame drum sander. I rarely need the 38” capacity and could probably have gotten away with purchasing the Woodmaster 26” drum sander. At any rate, I am very satisfied with the quality and performance of the machine. I use it exclusively to flush up panel glue ups. These machines are difficult to find used and are somewhat expensive new. But, in my experience, it is a solid performer.
View Heywood's profile
Heywood
46 posts in 1568 days
#6 posted 03-05-2016 03:35 AM
I own a Supermax and it really is a fine machine. Another great feature is the mobile base, I like to be able to move things around if need be. Good price and a US based company, another plus.
#7 posted 03-05-2016 12:31 PM
Woodcut1,
- JBrow
It always worked well for me on the Delta 18/36 I owned, but on that sander it was a matter of tuning it to be a few thousandths more open on the outside edge. I think with a Supermax (much better sander) I would try out of the box and see what happened. For a hobbyist (me) the open end gives the wider capacity without needing to occupy so much floor space and the power requirements of the larger machines. I’m not sure I’d recommend an open end for a production shop.
View Kazooman's profile
Kazooman
1117 posts in 2072 days
#8 posted 03-05-2016 01:41 PM
I have a Jet 16-32 Plus and it works very well. Jet has a 15% off sale going right now. You can get the sander online for $952 with free shipping. I did not purchase the overpriced Jet casters. I got a set at the local box store and they work just fine.
View splintergroup's profile
splintergroup
2253 posts in 1342 days
#9 posted 03-05-2016 02:42 PM
One thing that seems to get left out in comments on sanders is the price of the belt. I pay about $4-$5 per ‘refill’ on my 16/32. Since I buy belts in a big roll, an equivalent closed frame sander (32”) would cost $8-$10 per belt.
I’ve gotten better, but on occasion I will burn a belt. This basically makes the belt useless in the burned section. Narrow boards can be fed in the non-burned sections, but for a wide panel, the belt is basically useless.
Now, with my 16/32 I’m only out 50% of what I’d be out of with an equivalent closed frame.
Over the 10 years I’ve had my drum sander, I’ve probably spent as much on belts as the original machine.
Relatively minor I know, but still part of the cost/benefit analysis.
That being said, I think drum sanders are the #2 power tool to have (table saw being #1)*
  • subject to what type of WW you do of course!
View RogerM's profile
RogerM
798 posts in 2518 days
#10 posted 03-05-2016 02:43 PM
I am very satisfied with the 26” Shop Fox dual drum sander.
-- Roger M, Aiken, SC
JBrow
#11 posted 03-05-2016 03:02 PM
Woodcut1 and RogerM,
I have wondered whether I should have gotten a dual drum on the closed frame drum sander rather than the single drum I have. However, since I use a reversing switch which sends the panel through the sander and then returns the panel to its starting position, I am not sure whether buyer’s regret is justified.
After I sand a panel flush with 80 grit paper, I start finish sanding on the panel at 80 grit (on a journey to 180 or 220 grit). I find starting at 100 grit takes too long to remove sanding scratches from the drum sander. A second drum outfitted with 100 grit paper would perhaps allow me to start finish sanding at 100 grit, saving a little time. But I am not sure whether one pass under 100 grit paper on the drum sander would be enough to remove 80 grit scratches. Plus, as splintergroup points out, operating costs double with a dual drum sander. Nonetheless I still wonder.
Woodcut1
#12 posted 03-05-2016 03:03 PM
I noticed anything in the Supermax category the out feed extensions are optional. Does anyone find that this is a necessary purchase?
JBrow
#13 posted 03-05-2016 03:16 PM
Woodcut1
Out feed extensions are not necessary, but are sure handy. If you become distracted for whatever reason while sanding, it can keep the stock from dropping to the floor. The added support is nice when sanding an especially long and heavy panel. Since it is an accessory, the SuperMax can be used for a while without buying the extension. The usefulness of the outfeed support will probably be revealed; one way or the other.
View ScottKaye's profile
ScottKaye
681 posts in 2072 days
#14 posted 03-05-2016 03:59 PM
+1 on the Supermax.. I bring everything to final dimension on my 19-38. Its much more exactly and saves a few steps in the hand sanding process later. As and added bonus, both my jointer and to a certain extent my planer have small nicks in their blades. I’m not worried the least because I know the Supermax will take out the surface imperfections on the first pass. One other bonus that should be mentioned is that by sanding down to final dimension (we are talking .050 thickness or less ..) I can sand out all the snipe left from my planing operation. Paper changes take less then 5 mins.
-- "Nothing happens until you build it"
View RogR's profile
RogR
#15 posted 03-06-2016 03:42 PM
It depends on what you are sanding. For most of my purposes not only are the “optional” table extensions mandatory but I need extended roller bed outfeed support as well. When sanding long boards say, for a table top, the weight of the material hanging outboard of the table is sufficient to cantilever the stock up into the sanding drum – with various negative consequences. If you are mostly just truing up shorter parts, like cabinet doors and face frames, it might not be an issue.
Don’t forget, good dust collection is critical.
