Drillpres speed
Forum topic by majuvla posted 03-04-2016 02:13 PM 815 views 0 times favorited 14 replies Add to Favorites Watch
View majuvla's profile
majuvla
12074 posts in 2830 days
03-04-2016 02:13 PM
Hello all LJs,
I would like to know, from your own experience, which drillpress speed is comonly used for most of woodworking project?
I want to avoid constantly changing of top belt set-up and adjust one speed which will be sufficient for most of projects – so drilling from 3 – 40mm holes.
Thanks for all answers and suggestions.
Ivan
-- Ivan, Croatia, Wooddicted
14 replies so far
View Ger21's profile
Ger21
1074 posts in 3093 days
#1 posted 03-04-2016 02:27 PM
You’re not going to get good results when using one speed for 3mm to 40mm.
You can maybe get away with 1200-1500rpm for bits 20mm and smaller, but you really need to slow down with larger bits, or you’ll overheat them and ruin them.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View conifur's profile
conifur
955 posts in 1114 days
#2 posted 03-04-2016 02:40 PM
Also makes a big difference in speed with what kind of bit is being used, you would not want to run a Forstner bit as fast as a twist bit of the same size for example.
View TechTeacher04's profile
TechTeacher04
371 posts in 1494 days
#3 posted 03-04-2016 03:02 PM
Ivan,
You could shoot for something in the middle, but you are giving a wide variety of sizes. Changing speeds to match the bit and task will give you the best results and increasing your bit life and safety. You can use large forstner bit at high speed, but it will ruin the bit due to heat and could scorch your project in addition to possibly ripping it out of you hands. Consider taking the time to change speeds for the task or get a second drill press, one set for slow speed, the other set for fast.
View SuperCubber's profile
SuperCubber
1022 posts in 2247 days
#4 posted 03-04-2016 04:22 PM
Not sure if this helps, but I find it useful:
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
SuperCubber
#5 posted 03-04-2016 04:22 PM
Well, it looks difficult to read. If you want the PDF, PM me with your email.
View RichCMD's profile
RichCMD
393 posts in 1904 days
#6 posted 03-04-2016 04:43 PM
I like the chart, but never thought to look for something like it. I found a pdf version on-line without much trouble. Thanks for the idea.
-- Ride the bevel!
View MadMark's profile
MadMark
979 posts in 1415 days
#7 posted 03-04-2016 04:52 PM
I leave my drill press on the middle setting for 95% of my work. I drop to the slowest speed for forstners over 1”
It seems to work well on my cheap Skil 5 speed press. I’ve done a lot of drilling with it over the past 2 years and has served me well.
M
View Woodknack's profile
Woodknack
11475 posts in 2342 days
#8 posted 03-04-2016 11:35 PM
Mine is either on the fastest or slowest speed all the time. If I need it slow then I move it to slow where it stays until I need it fast. I’m too lazy to move belts all the time.
conifur
#9 posted 03-05-2016 12:19 AM
I have an Shop Smith ER 10 with the speed changer, on low speed setting it goes from 425 to 1100 rpm variable speed, for a dedicated DP love it.
View TheFridge's profile
TheFridge
9249 posts in 1448 days
#10 posted 03-05-2016 01:11 AM
First 3 speeds for wood. Last for wire wheels
View JBrow's profile
JBrow
1345 posts in 882 days
#11 posted 03-05-2016 01:44 AM
majuvla,
I set mine up at slow speed back years ago when I bought the drill press and have never changed the speed. Changing pulley locations to adjust the speed is time consuming, a little confusing, and just something I do not want to do whenever I drill a hole. I cut mostly wood, but on rare occasion a little metal. I drill at this same low speed regardless of material, hole size, or bit type. I watch the cut and adjust the rate of feed based on my observations. Am I getting the very best rests? I do not know but my holes are just fine and my bits continue to cut well.
majuvla
#12 posted 03-05-2016 07:48 AM
Thanks all for useful advices.
View REO's profile
REO
928 posts in 2036 days
#13 posted 03-05-2016 12:48 PM
Successful drilling is also a function of feed speed. The heat builds up not only because one has the speed is to fast bu also advancing the it through the material too slow. when feed slowly the chip created is smaller making it difficult to move or keep out of the way. The heat from the cutting edge is able to build up ahead of the advancing cutting edge and is not removed with the chip causing burnishing instead of a good cut. This heat is also hard on the cutting tool as well. when boring the hole for door handles with a forstner our machine is direct drive at 1725 rpm! But the typical drill press wouldn’t be powerful enough to match the feed and speed.
View stefang's profile
stefang
15881 posts in 3297 days
#14 posted 03-31-2016 02:10 PM
I like to change my speed to suit the job, but it is a bit tiring, so I only change it when great accuracy is an issue. Otherwise, I normally keep a medium speed, but I almost always change the belt to slow it down for large diameter work.
