Chainsaw Lumber Mill? After this video, maybe/maybe not
Forum topic by Holbs posted 03-04-2016 02:34 AM 1226 views 0 times favorited 13 replies Add to Favorites Watch
View Holbs's profile
Holbs
1984 posts in 2206 days
03-04-2016 02:34 AM
Topic tags/keywords: saw mill chainsaw
I know one day, I will venture into harvesting and milling my own lumber probably years down the road. What type of mill? Chainsaw would be the most economical. WoodMizer more practical. But here is a video showing the pro’s and con’s of using a chainsaw. The good part comes in around the 6 minute mark. The con’s :)
View on YouTube
13 replies so far
View bigblockyeti's profile
bigblockyeti
5261 posts in 1898 days
#1 posted 03-04-2016 02:58 AM
I have the “beam machine” that he first used to turn logs into cants and what surprised me more than anything was how much fuel the saw burned just cutting pine. Granted, the saw I was using at the time didn’t have a very big fuel tank, but cutting one side just a little over 9’ and ~12” thick burn about 90% of the total capacity and that was with a sharp chain too.
View gfadvm's profile
gfadvm
14940 posts in 2867 days
#2 posted 03-05-2016 01:20 AM
I had the Alaskan Chainsaw mill shown in the video when I first decided to mill logs to lumber. It was VERY labor intensive, slow, hard on chainsaws, and did I mention SLOW? I bought a used LT 15 Woodmizer and could not be happier with it. It took 62 days for it to pay for itself sawing in my spare time. And it is a LOT of fun!
View mahdee's profile
mahdee
4008 posts in 1945 days
#3 posted 03-05-2016 01:55 AM
Don’t do it with chainsaw. There is a guy near where I live that can make a potable bandsaw mill that cuts 43” logs for less than $6G’s. Almost $4G’s for a stationary one.
i
-- earthartandfoods.com
View MrUnix's profile
MrUnix
7008 posts in 2376 days
#4 posted 03-05-2016 02:25 AM
Have you ever seen the guys who mill it up with a chainsaw freehand (sans an attachment)? Pretty darn impressive and seems much faster than using the milling attachment – I believe because the angle of attack is much greater. Here is one such example. Note to the Safety police individuals out there – please refrain from comment :)
I’ve done it in a similar fashion and it does go pretty quick.. I just have to master the getting it straight part though!
TopamaxSurvivor
18380 posts in 3853 days
#5 posted 03-05-2016 02:52 AM
I have done the freehand thing. It works better than I thought it would. I usually mark a guide line to follow. It is a lot rougher than the guy in the video ;-)
View Jeepin85CJ7's profile
Jeepin85CJ7
71 posts in 1613 days
#6 posted 03-05-2016 03:05 AM
I recently got the Alaskan Mill, it is labor intensive but well worth the work. This time next year I’ll have red oak and maple slabs free at my disposal. Search around YouTube and I think you will be convinced the outcome far outweighs the labor!
runswithscissors
2874 posts in 2202 days
#7 posted 03-05-2016 03:50 AM
I had a beech log about 5’ long to slab. Bought a chain saw mill with a little different configuration. It had been designed for dressing logs for log home building. Mounted on 4 wheels, it would roll on the flat surface (slab) to make the first cut, then the log would be rolled 180 deg. and the opposite face would be slabbed. It made logs with perfectly flat and parallel surfaces.
In my case, I had to set up plank tracks for it to roll on. It worked okay, but making the 20” wide cuts was very slow going, even with a ripping chain. Had to sharpen frequently. I was glad I had to do that chore only once. If I had more of that kind of work to do, I would certainly look into a band mill. Also, the chain saw mill wastes a lot of wood with its huge kerf.
Actually, I did square off (more or less) the sides before starting to rip planks, and the free hand ripping was easier and quicker, as mentioned in posts 4 and 5 above.
bigblockyeti
#8 posted 03-05-2016 11:37 AM
I ve done it in a similar fashion and it does go pretty quick.. I just have to master the getting it straight part though!
- MrUnix
I think the angle of attack does make a significant difference. In my experience, the closer you can get to being parallel with the grain instead of perpendicular, the quicker the cut. A tree service guy I used to do a little side work for has a decent sized diesel powered portable band mill and though I can’t remember who makes it, the entire head carriage is skewed about 15 degrees from perpendicular and it apparently does quite well, of course I doubt anything with an 80hp turbo diesel is going to be too slow.
View Jeff2016's profile
Jeff2016
115 posts in 1041 days
#9 posted 03-05-2016 01:16 PM
I built my own chainsaw mill last fall, and have used the heck out it. I use a stihl magnum 460 with a 25” bar. Just sliced up some elm a couple weeks ago, and one cut on a 18” log took about 6 minutes.
What I’ve learned:
1) It is very labor intensive
2) Fuel is consumed at an alarming rate
3) Sharpen or change chains often
I am currently working on a bandsaw mill design and plan to use both. I don’t have room for a huge mill so I’ll use the chainsaw to bring larger logs down to a manageable size then run them through the bandsaw mill as it is far less labor intensive, and the blade kerf means more usable lumber from one tree.
Using either type of mill does open up a whole new world of wood. You can source logs everywhere, and I have yet to have to pay for one.
In my neck of the woods, cherry goes for about $4/4.50 a board foot. After stopping and talking to the road commision I slabbed 3 logs along side the road (the trees were dropped to widen the road) with my mill. Used about $20 in gas and oil, and came away with 16 slabs of flitch sawn cherry 4/4 to 6/4 8 to 10’ in length.
Just one of those boards would have cost me $32! I don’t count my labor since woodworking is a hobby and I am doing something I enjoy. It keeps me out of trouble anyway….
-- Proud owner of an electronics free workshop. Please check your cell phone at the door!
Holbs
#10 posted 03-05-2016 03:45 PM
I hope you all watched that video, if not for the humor and awesome music :)
Jeff… this is what I want to get into one day, as a hobby, so I have to balance return of investment. Knowing me, I would probably spring for a Wood Mizer than a new car :)
View WDHLT15's profile
WDHLT15
1788 posts in 2653 days
#11 posted 03-05-2016 04:18 PM
If you are doing much sawing, the chainsaw mill is like a horse and buggy versus the bandsaw mill, which is the model-T Ford. Nothing wrong with a chainsaw mill. It is just very slow, labor intensive, and not nearly as efficient as a bandsaw mill. It all depends on your objective.
View dhazelton's profile
dhazelton
2789 posts in 2474 days
#12 posted 03-05-2016 04:27 PM
$2,199 minus 20%. Plus it has good reviews. Setup probably takes some time but all Harbor Freight stuff does.
http://www.harborfreight.com/saw-mill-with-301cc-gas-engine-62366.html
Jeff2016
#13 posted 03-06-2016 01:58 PM
- Holbs
I here ya. If I had the money I would make the exact same choice. For what it is worth, if your handy with metal, a chainsaw mill is rather a simple build, and mine is 100% scrap metal and took about 5 or 6 hours. The only cost I have in building it was time. A band saw mill is a bit different though. I will be building one, but some parts will need to be purchased. I would love to just go buy a woodmizer though.
