How do I make this joint?
« back to Joinery forum
Forum topic by JK1972 posted 03-03-2016 10:33 PM 1045 views 0 times favorited 6 replies Add to Favorites Watch
View JK1972's profile
JK1972
5 posts in 827 days
03-03-2016 10:33 PM
Topic tags/keywords: joining
I have been asked to make this table for a friend. How do I make the “Y” joint with the 4×4 supports at the bottom of this table?
Thanks for any suggestions or advice,
John
View AandCstyle's profile
AandCstyle
3027 posts in 2222 days
#1 posted 03-03-2016 11:35 PM
The pic doesn’t show the joint clearly, but this one might work for you. HTH
-- Art
View conifur's profile
conifur
955 posts in 1116 days
#2 posted 03-03-2016 11:39 PM
I dont think so, I dont see a joint there at all, not like the pics Aand C style posted which you have only 30 seconds to look at.
View Adam's profile
Adam
41 posts in 2193 days
#3 posted 03-04-2016 03:09 AM
View JBrow's profile (online now)
JBrow
1348 posts in 884 days
#4 posted 03-04-2016 05:55 AM
JK1972,
An approach to simplify the joinery is to cut rabbets on the top and bottom surfaces of the 4” x 4” stretchers at the joining ends, perhaps ¾” deep, creating tenons. Then cut two wide ¾” thick pieces to the outline of the three stretches. The ¾” profiled pieces would then fit into the top and bottom rabbets. The ¾” profiled pieces could then be flushed up with the stretchers. The grain direction of the top inlayed ¾” stock would be orientated perpendicular to the grain direction of the bottom inlayed ¾” pieces – for strength. The gap in the butt cuts on the tenoned ends of the stretchers would be concealed by the top and bottom ¾” inlays.
View jerryminer's profile
jerryminer
916 posts in 1406 days
#5 posted 03-04-2016 08:59 AM
There’s this method:
3-way Stool Joint
View pete724's profile
pete724
53 posts in 773 days
#6 posted 03-09-2016 10:27 AM
Join the triangular legs with a triangular block.
Equilateral triangle 60 degree corners, thick block.
