Home made thickness sander
Forum topic by Chips posted 02-25-2010 04:01 AM 1915 views 0 times favorited 2 replies Add to Favorites Watch
View Chips's profile
Chips
199 posts in 3706 days
02-25-2010 04:01 AM
Topic tags/keywords: thickness sander question sanding
I bit the bullet and started building a thickness sander. I just sanded the drum round. Every thing looks good so far. The next step will be to mount the sand paper.
What is the best way to mount the sand paper? 1- Glue it to the drum? How do you change it if you do that? 2- Fasten it only on the ends using a wedge. Will this run smooth? 3- Velcro this has advantages but will the softness round the edges?
What is the best grit paper to use?
-- Make every day the best day of your life. Chips, Mississippi
2 replies so far
View jerryw's profile
jerryw
158 posts in 3910 days
#1 posted 02-25-2010 05:20 AM
i used psa velcro on mine , it worked just fine. no round edges. i fastened the ends of the sand paper down with 1/2 inch wide wrap of duct tape. never had it come loose.
-- jerryw-wva.
Chips
#2 posted 02-25-2010 03:48 PM
Good tip jerryw I am leading toward using Velcro. Never thought about fastening the ends good tip. Thanks. John
