Forum topic by KYSean | posted 03-03-2016 04:30 PM | 884 views | 0 times favorited | 14 replies | ![]() |
What is the best way to attach sandpaper to glass to use in tool sharpening? |
14 replies so far
#1 posted 03-03-2016 04:56 PM |
spray adhesive is what i use, after the paper is worn out a heat gun will soften the glue to remove it. |
#2 posted 03-03-2016 05:09 PM |
Spray adhesive, like 3M 77 I would say |
#3 posted 03-03-2016 05:11 PM |
I use contact cement as it’s pretty cheap and holds well. You have to replace the paper a while before you need it because it doesn’t dry nearly as quickly as spray adhesive. |
#4 posted 03-03-2016 05:14 PM |
I just spray the glass with windex and lay the paper right on the wet spot and spray sandpaper some more…. I feel like the sandpaper wears out so fast I’d rather not deal with spray adhesive… The sandpaper will move around a little bit, but it doesn’t bother me, plus its quick and easy cleanup. |
#5 posted 03-03-2016 05:16 PM |
I use spray adhesive and it is easy to remove when it is used up. -- Don Solomon, New Castle, IN; Quality is not an act, it is a habit. Aristotle |
#6 posted 03-03-2016 05:18 PM |
Water works for me. -- earthartandfoods.com |
#7 posted 03-03-2016 05:26 PM |
Thanks all. Is it best to set up 3 or 4 grits on the same glass? |
#8 posted 03-03-2016 05:38 PM |
I’ve got several grits on a piece of granite countertop 220 up 2000. I find it very convenient moving from one to the other to get that final edge. I’ve got other pieces of granite with different grits that I use for flattening the back of plane irons and chisel. |
#9 posted 03-04-2016 02:28 PM |
I am a big fan of the granite slab as opposed to glass as well. I used spray adhesive when I used to sharpen this way, or I would find self adhesive sandpaper rolls (even better). For silicon carbide water creates a good “stick” as well. -- Make furniture that lasts as long as the tree - Ryan |
#10 posted 03-04-2016 02:32 PM |
https://www.toolsforworkingwood.com/store/item/st-maf.XX On granite and you’re good to go. |
#11 posted 03-04-2016 02:42 PM |
I like to use near full size sheets, so I have 3 pieces of glass with paper on both sides. I keep meaning to try the water trick, thinking I could just switch the paper but haven’t gotten around to doing so. I use spray adhesive at the moment. -- Our village hasn't lost it's idiot, he was elected to congress. |
#12 posted 03-04-2016 03:15 PM |
+1 waho6o9 -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees. http://thecanadianschooloffrenchmarquetry.com/ |
#13 posted 03-05-2016 01:41 PM |
Glass or granite makes no difference to me. I use a light oil as a sharpening lube, you could use water, and let it soak the wet/dry paper. It will stay in place well enough. I prefer oil so I don’t have to deal with as much rusting. |
#14 posted 03-05-2016 01:54 PM |
Good old spritz of water is all you need. Wet the paper and it will stick just fine. -- Sooner or later Liberals run out of other people's money. |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2102 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4899 |
6689 |
28036 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6223 |
1387 |
Focus on the Workspace
2152 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
