Gluing tenons
Forum topic by Mike posted 02-24-2010 10:19 PM 1463 views 0 times favorited 4 replies Add to Favorites Watch
View Mike's profile
93 posts in 3094 days
02-24-2010 10:19 PM
Hello all
I am doing some small box stuff with mortise and tenon. 1/8” Tenons on the end of 1/4” thick maple sides into 3/8” thick walnut ends.
Question is, do you generally glue just the tenon or do you put glue in the mortise also?
Thanks for the help
-- Mike, Cantral Oregon
View Brian024's profile
358 posts in 3330 days
#1 posted 02-24-2010 10:56 PM
Both, but mainly because all of the videos I’ve watched, the builder did.
View bladeburner's profile
88 posts in 3017 days
#2 posted 02-25-2010 12:24 AM
I put glue on the leading half of the tenon and swab some just into the mortise. I don’t get any squeeze out this way.
View richgreer's profile
4541 posts in 3004 days
#3 posted 02-25-2010 01:14 AM
Make sure to check this out for a good tip on avoiding squeeze out – -
The older glues (Elmer’s) always said you should put glue on both surfaces. The newer glues (Gorilla Wood glue) say you only need glue on one surface. I’m not sure where Titebond is on this question.
View Mike's profile
#4 posted 02-25-2010 07:46 AM
Thanks guys
I did see that vidio but with only 1/16” or less of coverage outside the mortise I don’t want to try that on these little moritses.
I will try just gluing the tennon and the mortise and not the sholders and see how that works. I was concerned aobut hold strength so I had put glue on the shoulders and had a lot of wiping in a couple of the inside corners.
