Crown Molding
Forum topic by Greyeyes posted 03-03-2016 01:20 PM 604 views 0 times favorited 5 replies Add to Favorites Watch
View Greyeyes's profile
Greyeyes
2 posts in 841 days
03-03-2016 01:20 PM
Topic tags/keywords: question
Hello
I am in the process of installing crown molding in our home. I have run into an issue where the vaulted ceiling meets the flat ceiling. Does anyone have any ideas on how to transition from one to the other. I will have 4 of these to install. I have attached a photo of what I mean. Any help would be appreciated.
Gord
-- Woodworking is fun
5 replies so far
View hotbyte's profile
hotbyte
991 posts in 3001 days
#1 posted 03-03-2016 02:47 PM
Are you wanting to run the crown up the vaulted ceiling portion or end at that point?
If you want to end at flat ceiling, put a little “turned back” piece using an outside miter..
View TechTeacher04's profile
TechTeacher04
386 posts in 1557 days
#2 posted 03-03-2016 04:08 PM
You could install a plinth block, it would allow for an easier transition without creating a shadow from the returns mentioned by hotbyte.
View cabmaker's profile
cabmaker
1735 posts in 2835 days
#3 posted 03-03-2016 11:00 PM
uhhhhh….plinth block….shadow ?
You can mill a transition block for that union .
don’t know where your crown is from but a serious dealer that deals in custom moldings will have a partnering profile for different pitches that will match up on the rake.
If your crown is from the big box, they won’t have any idea what that is
From what i see in the pic your sorta stuck with a transition block due to the offset in your transition.
on the other hand…..appears it will paint so you can always shave and butcher to get within a suitable tolerance that will allow you to caulk and fill successfully
Enjoy the journey amigo ! JB
Greyeyes
2 posts in 841 days
#4 posted 03-06-2016 09:56 PM
Thanks for the replys. This advise will help.
View waho6o9's profile
waho6o9
8207 posts in 2602 days
#5 posted 03-06-2016 10:03 PM
Bing images have a ton of ideas also.
