Bit Selection for 3D Signs
« back to CNC Woodworking forum
Forum topic by Proflemoi posted 02-29-2016 05:25 PM 666 views 0 times favorited 2 replies Add to Favorites Watch
View Proflemoi's profile
37 posts in 955 days
02-29-2016 05:25 PM
Hello All,
I have been making a few signs for family and friends on my CNC… on several of the signs I have a contoured edge. I am using VCarve Pro and selecting one of the Panels from the clip Art. The bit I am using for the edge work is a 1/4” Ball nose… I got to wondering about using a more traditional router bit, say a Ogee for example… could I use this type of bit and simply cut a parameter around the sign? Thoughts?
Thanks !
Prof L
-- Probotix Asteroid
2 replies so far
View ChrisK's profile
1934 posts in 3014 days
#1 posted 02-29-2016 05:45 PM
You can use an ogee, you just need to calculate the offset of the bit and make a tool path offset to cut the edge.
Might be faster to make the cut on a router table instead of the CNC.
-- Chris K
View Ger21's profile
1074 posts in 3063 days
#2 posted 02-29-2016 05:45 PM
Yes. You can add custom tools to the tool database. You just need to draw the profile.
See the manual.
-- Gerry,
