Makita slide compound question
Forum topic by Dee1 posted 02-29-2016 04:10 PM 588 views 0 times favorited 4 replies Add to Favorites Watch
View Dee1's profile
Dee1
296 posts in 1939 days
02-29-2016 04:10 PM
I have a Makita LS1013 and it has not been used a lot, but it gets very stiff going from 90 deg to 45 or back and fourth. nothing in manual about this but it is a pain?
Dee1
View Dutchy's profile
Dutchy
3003 posts in 2218 days
#1 posted 02-29-2016 04:32 PM
I would try WD 40
-- https://dutchypatterns.com/
View ShaneA's profile
ShaneA
6965 posts in 2648 days
#2 posted 02-29-2016 05:55 PM
Are you unlocking it properly, and the path is not obstructed by anything?
View jerryminer's profile
jerryminer
935 posts in 1491 days
#3 posted 03-01-2016 03:33 AM
You probably have some sawdust or other crud binding up the table. Blow out the debris with compressed air. Spray in some WD-40 or other lubricant. Getting in under the saw is best.
View bdresch's profile
bdresch
148 posts in 1658 days
#4 posted 03-01-2016 03:46 AM
I have this same model. Are you loosening up the lock lever enough? To get mine to move in the bevel direction smoothly I need to loosen it at least a 1 full revolution. There is also a set screw with a spring under it, item 105 in the picture below. If I remember correctly, that sets the tension of the detent ball. You could try backing that out a half turn. Don’t take it all the way out or the spring and ball may go flying!
