Keeping Router bits sharp
Forum topic by Wiley posted 02-23-2010 05:01 AM 1890 views 0 times favorited 12 replies Add to Favorites Watch
View Wiley's profile
71 posts in 2961 days
02-23-2010 05:01 AM
Topic tags/keywords: question router bits sharp
Personally, I think my garage is built over the site of an ancient power tool burial ground. Or perhaps I have an infestation of workshop gremlins. I’ve advanced both of these theories to my friends at the local Rockler, and they say it’s more likely to be “operator error.” Whatever the cause, I can’t seem to make a router bit last more than a week of making box joints before it starts getting uncooperative and chewing up large chunks of wood. What are the “best practices” for being nice to your router bits and making them last?
-- "When you lose the power to laugh, you lose the power to think straight" - Inherit the Wind
12 replies so far
View ahock's profile
102 posts in 3254 days
#1 posted 02-23-2010 05:12 AM
-Keep them clean
-Take small bites
-Use the right speed
-If using consistently let them cool down
-- Andy, PA ~Finding satisfaction in creation
View Jeison's profile
968 posts in 3038 days
#2 posted 02-23-2010 05:15 AM
-hire shaman to appease spirits of deceased tools haunting said burial ground
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View williams's profile
53 posts in 2947 days
#3 posted 02-23-2010 05:19 AM
No expert, but all can think of.
1) pull the nails and screws out first. :-)
2) keep the heat down with smaller passes. Heat is enemy of bits.
3) Naturally, keep bottom of bit 1/8” above collet.
4) wet end grain for less tear out and may help with heat.
5) use right speed
-- William, Brighton, MI
View Greg Elam's profile
Greg Elam
29 posts in 2971 days
#4 posted 02-23-2010 05:31 AM
One other thing to keep in mind is if you have a fairly good quality bit some profiles can be sharpened. A fellow in my area will sharpen them for much less than the price of a new one.
-- Greg Elam - Berea, Kentucky
View Sawkerf's profile
1730 posts in 2999 days
#5 posted 02-23-2010 06:09 AM
HSS or carbide?
-- Adversity doesn't build reveals it.
View richgreer's profile
4541 posts in 3005 days
#6 posted 02-23-2010 06:14 AM
The suggestions above are very good regarding taking small bits and keeping them cool. I’ve had quite a few router bits that got dull very quickly and a few that seem to stand up to the test of time. There seems to be a definite correlation between the quality/price of the bit and how well it holds up. For what it is worth, I have found that Freud bits hold up the best for the long term.
#7 posted 02-23-2010 06:18 AM
They’re carbide, made by Rockler. I’m a bit worried about getting them sharpened because I use them for box joints. How much smaller does sharpening generally make a straight bit?
View Routerisstillmyname's profile
763 posts in 3440 days
#8 posted 02-23-2010 06:46 AM
Freud router bits.
nuff said.
-- Router รจ ancora il mio nome.
View knotscott's profile
7935 posts in 3306 days
#9 posted 02-23-2010 02:25 PM
It might be time to consider an upgrade….Freud (as mentioned), Whiteside, Infinity, Eagle America, CMT, Amana, Katana….
View bob101's profile
321 posts in 3381 days
#10 posted 02-23-2010 05:39 PM
keep them clean, and make small passes, on the sharpening note I use a flat folding diamond hone from lee valley tools for my router bits(carbide) all you need to do is make light passes on the flats of the bit(clean bit), and bob’s your uncle youre done, they usually end up sharper than when initialy purchased.
-- rob, ont,canada
View Mark's profile
1807 posts in 3204 days
#11 posted 02-23-2010 06:01 PM
freud like he said ^ theyre eternal
-- M.K.
#12 posted 02-23-2010 06:53 PM
Correct sharpening of a bit doesn’t remove material in a way that reduces the diameter of the bit. The operative word, of course, is “correct”. – lol
