HF DC
Forum topic by cebfish posted 02-29-2016 02:55 PM 2666 views 8 times favorited 68 replies Add to Favorites Watch
View cebfish's profile
cebfish
152 posts in 2558 days
02-29-2016 02:55 PM
Topic tags/keywords: question
Has any one used large truck air filters on their DC if so how good does it work.I have 2 the area of the filters are smaller than the bag. I was wondering how big of problem that is. I did a quick test seemed to work fine with better suction just don’t know long term
68 replies so far
View hotbyte's profile
hotbyte
989 posts in 2846 days
#1 posted 02-29-2016 02:58 PM
Which filters are you trying? I’ve read several posts here where someone has used Donaldson filters.
Do you mean the area of the filters is larger than the bag? That is supposed to be one of the benefits (besides better filtration) is more surface area with pleated filters.
cebfish
#2 posted 02-29-2016 03:02 PM
They are CATERPILLAR . The filters are smaller than the bag I took off . they are really off of bull dozers. The OD is 16’’ ID 9’‘
hotbyte
#3 posted 02-29-2016 03:15 PM
With pleated filters, the way the filter material folds back and forth gives them an overall larger surface area than an bag filter of same diameter would have. So, even though the OD is smaller, you might have a larger filter surface area.
You also need to know what size particle the filters will filter. The HF DC bag is 5 micron. It would be better if 0.5 or 1 micron. A lot of the filters are rated in MERVs which I’m not sure about. Hopefully someone will chime in on what MERV rating is equivalent/similar to micron rating.
View shipwright's profile
shipwright
7847 posts in 2668 days
#4 posted 02-29-2016 03:17 PM
Yes, I have and they are great. The one on the DC in this blog is a Donaldson p181099 and for my purposes it is completely adequate and certainly better than the bag. If you want one equivalent to the Wynn 35A, use the p181035. It is virtually identical at half the price.
View ste6168's profile
ste6168
252 posts in 1042 days
#5 posted 02-29-2016 03:28 PM
- shipwright
I searched that part number, and it doesn’t look identical. What are the fins near the bottom? Also, showing an OD of only 9.21” – That cannot be right. I would love to find a replacement filter, but not interested in a $200 Wynn.
hotbyte
#6 posted 02-29-2016 03:32 PM
Shipwright,
I was just checking your blog and you list the Wynn equivalent as a P181038 in it instead of the P181035…
View ohtimberwolf's profile
ohtimberwolf
736 posts in 2223 days
#7 posted 02-29-2016 03:55 PM
I conferred with shipwright and did what he did only I used the larger filter I got off of ebay. Cost me $84.75 with shipping. It was the 038. Quite happy with it so far. Using it in one bay of a three car garage. larry
-- Just a barn cat, now gone to cat heaven.
View DirtyMike's profile
DirtyMike
637 posts in 772 days
#8 posted 02-29-2016 04:28 PM
ohtimberwolf
#9 posted 02-29-2016 05:22 PM
DirtyMike, that is where I got mine. Good and Fast service. No regrets. larry
Here are the details on the filter
https://catalog.donaldson.com/productDetail/en/A/P181038?productId=17801&skuId=s32280
View ChrisK's profile
ChrisK
1865 posts in 2952 days
#10 posted 02-29-2016 06:08 PM
http://www.allfilters.com/airfilter/mervrating
A quick what is a MERV rating article.
-- Chris K
cebfish
#11 posted 02-29-2016 06:48 PM
Thanks everybody . If i do the math the OD of the filter compared to OD of the bag the filters are larger. The filters are 10’’ higher. I got the filters for free. I ran it for about half hour cleaning up the shop floor. I kept a check to make sure it did not overheat the motor it did not
DirtyMike
#12 posted 02-29-2016 09:08 PM
quick question, machine filters use an efficiency % and hvac and health filters use a merv rating. Is there a way to convert the ratings?
I have worked on drill rigs that made the worst dust you can imagine. at the end of the day we would tap out our air filters and pounds of fine dust would come out of the outside pleats, not a spec on the inside. so imagine a 99.9 % filter is pretty high on the merv rating.
View The__Dude's profile
The__Dude
125 posts in 933 days
#13 posted 03-01-2016 12:12 AM
What about people who have the collector outside?
Isnt less micro size better for flow?
ohtimberwolf
#14 posted 03-01-2016 01:17 AM
Here is a chart from where ChrisK directed.
shipwright
#15 posted 03-01-2016 01:32 AM
Sorry about the 035/038 mistake. I did the original comment from memory, checked and found the error, and then edited the post. I must have neglected to “save changes”. It really sucks getting old. :-(
showing 1 through 15 of 68 replies
