painted walls and lighting
Forum topic by popmandude posted 02-23-2010 03:23 AM 1263 views 0 times favorited 9 replies Add to Favorites Watch
View popmandude's profile
popmandude
109 posts in 3048 days
02-23-2010 03:23 AM
Hey folks. I am fixin to paint my garage ceilieng, and walls to help enhance lighting. I was just wondering if anyone has ever used a semigloss paint to enhance the effect. Any thoughts would be appreciated.
Thanks
Randy
9 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 3071 days
#1 posted 02-23-2010 03:25 AM
Randy, I used a semigloss white and it helped brighten up the shop quite a bit.
View NBeener's profile
NBeener
4816 posts in 3202 days
#2 posted 02-23-2010 03:52 AM
If you got REALLY bored, you could learn a fair amount from this article.
In short, the lighter the color, and … the higher the gloss level … the higher the reflectivity.
Good info here, too.
I may end up going with the full glossy, if/when I get to painting mine….
-- -- Neil
popmandude
#3 posted 02-23-2010 04:49 AM
Thanks for the input folks.
Hey Beener, those links were very “enlightening” so to speak. I thought about full glossy myself, but as my shop is 20’x20’ that may be overkill.
Thanks again
Randy
View ahock's profile
ahock
102 posts in 3352 days
#4 posted 02-23-2010 05:13 AM
Just a note about glossy paints: If you ever want to repaint, you’ll either need to sand the entire surface with 120 grit so new paint can stick, or do at least one coat of a GOOD oil based primer to get anything to stick to it well.
-- Andy, PA ~Finding satisfaction in creation
View dannymac's profile
dannymac
144 posts in 3044 days
#5 posted 02-25-2010 04:12 AM
i just used a couple of coats of primer on my ceillings and walls. seems to have worked great with the flouresants. down side is i seem to be cleaning more often. dam i can see everything.
-- dannymac
Rick Dennington
5912 posts in 3222 days
#6 posted 02-25-2010 04:53 AM
Greetings…... When I painted my shop 7 years ago when I built it, I put 2 coats of Kilz oil base primer on the walls and ceiling, then 2 coats of interior laytex semi-gloss in white. I have 16—- 8 ft. T-8 lights, and with the paint and light, it’s good and bright….... white paint really helps….... take a look at my shop…
View grub32's profile
grub32
215 posts in 3076 days
#7 posted 02-25-2010 05:01 AM
I agree… I did 2 coats of primer and then 2 coats of a walmart brand semi gloss and it made a huge difference no joke. even helps eliminate dark corner.
definitely worth the money.
Grub
-- Educator by Day, Wood Butcher by Night!!
View sparks's profile
sparks
62 posts in 3117 days
#8 posted 02-25-2010 05:45 AM
I am a 3rd generation painter and gloss paint tinted off white or light gray is better then just white. First it covers better and the light doesn’t glare as much. As for having to oil base prime or sand if you ever want to repaint is not the case anymore with the new paints. Back when paints were oil base or the first generation of latex paints came out this was true. Get a good quality acrylic paint (or latex, acrylic is better and more durable) tinted to an offwhite or gray and apply 2 to 3 coats. Gloss works best in a shop because it cleans up the best especially around light switches from dirty hands. If u ever want to paint over it u can prime with an acrylic primer 1 coat and then paint. If it were mine id paint the ceiling with a satin finish( its cheaper) and then paint the walls with a semi-gloss or gloss(best choice). Light won’t reflect as well off the ceiling as it does on walls, so that’s why u don’t need to waste the money. Hope this helps. If u need anything (except the labor) feel free to contact me.
-- Sparks
View ROY53's profile
ROY53
77 posts in 3206 days
#9 posted 02-25-2010 06:30 PM
I epoxyed my shop floor as well. It not only helps with the lighting, it’s a breeze to clean.
-- Roy L, Arizona
