Router Insert Plates
Forum topic by Lee Imbimbo posted 02-23-2010 12:55 AM 1271 views 0 times favorited 2 replies Add to Favorites Watch
View Lee Imbimbo's profile
Lee Imbimbo
69 posts in 2948 days
02-23-2010 12:55 AM
We’ll I have all the pieces for my Router Table except for the Miter Track and the Router insert plate. I’m thinking about the Incra Aluminum Router Plate for my Triton TRC-001 Router, and the Kreg Dual Track. From everything I’ve come across I think this combination would work really well and serve almost any need I can come across for my Router Table.
I wanted to see if anyone else had any bad experiences with the Incra Plate and Kreg Dual Track. I’m hoping to get this stuff ordered this week so that I can get the Table built by the end of March.
Thanks for the help.
2 replies so far
View Glen Peterson's profile
Glen Peterson
556 posts in 2932 days
#1 posted 02-23-2010 04:09 AM
I just bought the woodpecker aluminium insert plate also to use with the Triton TRC-001. I just got it and haven’t and I’m in the building process too. If the Incra fits the Triton router, I think you’ll be OK. I chose aluminium for it’s rigidity. Sorry I don’t have experience with the Incra plate, but they seem to make quality products. I also don’t know about the kreg track. I have ordered most of my T-track from Peachtree recently, I’ve seen the kreg track and it seems nearly identical.
-- Glen
Lee Imbimbo
#2 posted 02-25-2010 07:42 AM
Does anyone have experience with the woodpeckers combination track. It seems like it would be a slightly cleaner installation.
Almost every other track uses screws to mount the track, which I would suspect could potentially bind a miter guage, as it collects sawdust and builds up. The woodpeckers track has the added benefit of being mounted using 1/4” bolts from underneath, and it could even supply a place to adhere a ruler.
Not to mention the woodpeckers track is almost ten dollars cheaper than all the others.
Thanks for your posts.
