Calculating board feet when board will be used in their side?
Forum topic by yellowtruck75 posted 02-28-2016 11:55 PM 764 views 0 times favorited 11 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3216 days
02-28-2016 11:55 PM
Trying to figure out the board feet need for a shuffle board table. The hard maple will be used on its side instead of the face so I am confused as to how to figure out board feet.
Playing surface is 3” thick 20” wide and 12’8” long
I plan on using 8/4 stock
11 replies so far
View conifur's profile
conifur
955 posts in 1301 days
#1 posted 02-29-2016 12:15 AM
It is simple math if you know how to do math? I can do it without a calculator, in my head, Kids!!!
Roughly 50+ Brd Ft. 5 brd ft for each 3×13 ft piece, 20w divided by 8/4, 2 inches =10, 10×5brd ft =50
What the freck they teach in school now a days????
View joey502's profile
joey502
544 posts in 1667 days
#2 posted 02-29-2016 12:16 AM
The calculation is the same. Board foot is a unit of volume not area. 12”x 12” x 1” = 144 cubic inches = one board foot.
In your case 3×20x152= 9120/ 144= 63.333 board feet, after being milled.
View Joe Lyddon's profile
Joe Lyddon
10266 posts in 4201 days
#3 posted 02-29-2016 12:20 AM
8/4 stock is 2” thick
12’ = 144” + 8” = 152” long
3×20 x 152 = 9120 / 144 = 63.33 bft.
I think… :)
So, you are going to rip everything into 3”+ strips… plane, etc. & glue them together to get 2 slabs 10” wide, then glue them together to get 20”??
Sounds like FUN!
conifur
#4 posted 02-29-2016 12:24 AM
Actually a bit less 3 divided by 12 is 4brd ft but I a lotted for 13ft and checked ends and scrap.
joey502
#5 posted 02-29-2016 12:24 AM
The 8/4 stock will need to be milled, lets say you get 1 3/4 of finished stock from each board. That means each 3” wide strip is 5.54 board feet ( 3”x 152” x 1 3/4”).
Everything depends on the amount of usable material each board you buy yields. If you buy 6” wide boards then you can not get 2 3” pieces unless you are willing to change the thickness. If you buy 8” boards there will be waste after you cut two strips from it.
conifur
#6 posted 02-29-2016 12:41 AM
My mistake on my calculation, yes 8/4 yields 1 3/4”’ not 2”’
Joe Lyddon
#7 posted 02-29-2016 01:19 AM
BDFT is calculated AS IF things were really 1, 2, 3, 4, etc. 4//4 = 1… 8/4 = 2 for BDFT calculations…
Building wise, figure the real dimensions… not the make believe ones… LOL Right?
If you rip’em using a band saw, you will not wast 1/8” per cut… You must figure kerf size and get the boards wide enough to give you the least amount of waste. If using a 1//8” kerf, figure 1/4 for cleanup,,, so 3.25” strips is what you should figure on… 6.5”(2), 9.75(3), 13”(4) widths…
conifur
#8 posted 02-29-2016 01:23 AM
If you rip em using a band saw, you will not wast 1/8” per cut… You must figure kerf size and get the boards wide enough to give you the least amount of waste. If using a 1//8” kerf, figure 1/4 for cleanup,,, so 3.25” strips is what you should figure on… 6.5”(2), 9.75(3), 13”(4) widths…
- Joe Lyddon
conifur
#9 posted 02-29-2016 01:26 AM
Kirf, if you the right rip blade you may not need any clean up, if not, a 32nd to 16th at most, if you need a 1/4 a Beaver must be doing your ripping
conifur
#10 posted 02-29-2016 01:39 AM
If with the right blade and tension, and a good fence and set up for drift.
View bigJohninvegas's profile
bigJohninvegas
491 posts in 1611 days
#11 posted 02-29-2016 02:42 AM
At 13’ long it comes out to 65bf.
I keep a board foot calculator on my phone. Free download from the play store.
Yes simple math. Simple calculator too, and I make less math mistakes that cost me money.
Good luck.
-- John
