Gluing handles to painted drawer front?
Forum topic by abehil posted 02-28-2016 06:15 PM 699 views 0 times favorited 9 replies Add to Favorites Watch
View abehil's profile
abehil
104 posts in 1215 days
02-28-2016 06:15 PM
I have made some drawers for a shop tool stand and the fronts are 3/4” plywood. I’d like to spray a clear coat onto the drawer fronts. I made some wood handles out of of some 2×4 material because that’s all I have to work with and I’m considering gluing them on to the fronts rather than use screws.
The plywood is sanded 5 ply poplar but the poplar is a veneer layer I think.
Should I be concerned that the paint (Rust-oleum can spray paint) will be the weak spot or does enamel paint bond well enough to hold? What glue to use? I have 5 minute epoxy on hand and could use that.
9 replies so far
View jbay's profile (online now)
jbay
1942 posts in 775 days
#1 posted 02-28-2016 06:50 PM
I would screw them regardless. Why not?
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View splatman's profile
splatman
586 posts in 1275 days
#2 posted 02-28-2016 07:04 PM
Stick squares of masking tape a bit smaller than the glue surfaces of the handles, where the handles will go. After finishing, peel the tape, and there will be 2 bare wood spots for the glue to adhere. Make sure there is no finish on the glue surfaces of the handles.
116815 posts in 3453 days
#3 posted 02-28-2016 07:06 PM
As J said I would screw them also.To answer your question you probably will have and adhesion problem. If your concerned about drilling the holes for the handles, a easy jig will make it easy .
https://www.youtube.com/watch?v=CYQRCfgIR2A
abehil
#4 posted 02-28-2016 08:23 PM
splatman: Thanks. The masking tape could work for me.
jbay and a1Jim: I’m confused about the proper screws so glue sounded easier. I ordered some 8/32 truss head screws but fine threads in soft wood didn’t seem right to me. So I also ordered 8/32 ez-loc threaded inserts to put in the handles but they are only 1/3” so it seems like that’s too shallow and the soft wood handle would break off sooner or later. Your thoughts?
View TheFridge's profile
TheFridge
8675 posts in 1362 days
#5 posted 02-28-2016 08:30 PM
Uh. Wood screws.
View rwe2156's profile
rwe2156
2756 posts in 1357 days
#6 posted 02-28-2016 09:11 PM
What you’re trying to do will, of course work, but you’re making way too much of it.
Screws—->Wood screws—->Pan heads—->1 1/4”—->Drilling template——-| Done.
abehil
#7 posted 02-29-2016 01:19 AM
rwe2156: Thanks, that explains alot.
TheFridge: Uh. Nothing is obvious the first time you do it.
abehil
#8 posted 03-03-2016 05:42 PM
I ended up using 2-1/2” kreg pocket screws because I just happen to have some. The drawer box is 1/2” and the drawer front is 3/4” so the drawer itself is 1-1/4” thick. These are large handles made of soft wood and will be in the garage so guaranteed that they will get knocked and I don’t want them to break off.
The screws come to about 3/8” or 1/2” from outer curve of the handle.
Thanks again for all the suggestions. This has been a fun project. It’s the first time I’ve made drawers or handles or a cabinet or attempted making them flush inset (which worked and looks great).
View Woodchuck2010's profile
Woodchuck2010
704 posts in 735 days
#9 posted 03-03-2016 05:52 PM
I really like your cabinet. Looks great! Have the build plans for it?
-- Chuck, Michigan,
