Router Table Material
Forum topic by rockom posted 02-22-2010 05:52 PM 909 views 0 times favorited 5 replies Add to Favorites Watch
View rockom's profile
rockom
134 posts in 3746 days
02-22-2010 05:52 PM
I was wondering, has anyone used real wood for a router table surface?
The majority of tops are laminated fiber board, or layers of ply and MDF.
Why not have a glued up surface. Butcher block or workbench style?
This could be glued to an MDF and ply substrate right?
A finish can be applied to reduce friction.
What’s the drawback? Will flatness over time be much different than plywood and MDF?
Thanks,
-Rocko
-- -> Malta, IL -<
5 replies so far
View JimmyNate's profile
JimmyNate
124 posts in 3226 days
#1 posted 02-22-2010 08:19 PM
I’ve wondered this myself. I suspect it’s just cheaper to get a slick, flat surface with laminate. Also, ensuring that the top is sag-free over time while bearing the weight of the router underneath seems to be an important concern.
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3162 days
#2 posted 02-22-2010 10:09 PM
I did make mine out of solid wood. It is butcher block maple. It would have been expensive for the maple, but I had it leftover from a job. I covered mine with Formica, and it works great. I didn’t want MDF for my router table.
Check it out here
http://lumberjocks.com/projects/17441
-- http://shepherdtoolandsupply.com/
View miles125's profile
miles125
2180 posts in 3881 days
#3 posted 02-22-2010 11:03 PM
MDF is so great because its less likely to move (e.g..twist, bow, sag, cup, warp). All of which would make a router table a PITA to use.
-- "The way to make a small fortune in woodworking- start with a large one"
View sambo56's profile
sambo56
13 posts in 2889 days
#4 posted 02-24-2010 01:30 PM
I used baltic birch for mine. The stuff is solid, stable and will last forever. You can still cover it with formica or whatever if you want, but I haven’t had any problems without.
-- Rick, Canada, http://www.table-saw-guide.com
rockom
#5 posted 02-24-2010 07:50 PM
Thanks all for your replies.
Baltic birch sounds like a nice idea with a wood trim.
-Rocko
-- -> Malta, IL -<
