Variable speed router?
Forum topic by DirtyMike posted 02-28-2016 04:29 AM 654 views 0 times favorited 6 replies Add to Favorites Watch
View DirtyMike's profile
DirtyMike
637 posts in 806 days
02-28-2016 04:29 AM
Hello jocks, I am about to purchase a couple of routers, a trim router and a 3 1/4 hp plunge router. how important is variable speed on bigger routers? The 3 1/4 hp will be my workhorse for mortises and templates. I already feel like the variable speed is worth 50 bucks more. thanks
View MadMark's profile
MadMark
979 posts in 1357 days
#1 posted 02-28-2016 05:03 AM
If you intend to swing big bits in that big router VS is a must. Most big bits (over 1” dia) will come with a ‘max RPM’ spec that needs to be observed. The bigger the bit the slower the RPMs.
M
DirtyMike
#2 posted 02-28-2016 05:38 AM
thanks mark, seems like i have forgotten about physics.
View toddbeaulieu's profile
toddbeaulieu
810 posts in 2908 days
#3 posted 02-28-2016 01:55 PM
You absolutely want VS! I always run mine at what seems like the lowest appropriate speed. Varies depending on the bit size and even the material, since some woods burn easily at higher speeds.
View Logan Windram's profile
Logan Windram
344 posts in 2366 days
#4 posted 02-28-2016 02:07 PM
Flexibility is always a good thing. I am leaning more towards getting a shaper with router insert and doing away with a router table…or getting one as a leaf on my table saw.
runswithscissors
2652 posts in 1929 days
#5 posted 02-29-2016 08:21 AM
I went from a router table to a shaper (older Jet 2 hp), and haven’t regretted it. Induction motors are quieter and more powerful (regardless of claimed “horsepower” on universal motors). Some say the highest speed of most shapers (1100 rpm) won’t give as smooth a cut as a high speed router, but I used router bits often and have not noticed any lessening of cut quality. But maybe my standards are too low.
View Ger21's profile
Ger21
1074 posts in 3035 days
#6 posted 02-29-2016 01:40 PM
A 3-1/4 HP router can get tiring pretty quickly when your holding it in your hands. You might want to consider a 2-1/4 HP plunge router for handheld work, and a 3-1/4 for a router table.
I highly recommend variable speed for every router you own.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
