Collins Planer [Blades?]
Forum topic by Bud2 posted 02-28-2016 01:03 AM 2635 views 0 times favorited 10 replies Add to Favorites Watch
View Bud2's profile
Bud2
33 posts in 1219 days
02-28-2016 01:03 AM
HI, I got this Collins planer No; TG19001 and need to know if anyone can help me out with what type of blades I need to get to replace these?? I have looked and looked and cant come up with anything, Is it a big project to replace the blades? I have had it for a year and am happy with it and used it alot, Maybe somewherer I can get a owner manual? Just not having any luck on this computer looking for this, THANKS
10 replies so far
View MrUnix's profile
MrUnix
6719 posts in 2200 days
#1 posted 02-28-2016 01:16 AM
Never heard of Collins.. but it appears the full name is “Collins Quality Tools”, and there does seem to be quite a few belts available for that machine on e-bay :) I’d pull the old knives and measure them. Chances are they are a pretty standard size. Then take your knives to get sharpened, so you can continue using the machine while you look for new ones. You should be able to sharpen them many times before they are no longer usable, so that would give you lots of time to search.
View AlaskaGuy's profile
AlaskaGuy
4144 posts in 2310 days
#2 posted 02-28-2016 02:16 AM
Never heard of Collins.. but it appears the full name is “Collins Quality Tools”, and there does seem to be quite a few belts available for that machine on e-bay :) I d pull the old knives and measure them. Chances are they are a pretty standard size. Then take your knives to get sharpened, so you can continue using the machine while you look for new ones. You should be able to sharpen them many times before they are no longer usable, so that would give you lots of time to search.
- MrUnix
Brad have you never heard of the Collins coping foot? They have been around for years.
https://youtu.be/ZHZPsAhVfzQ
MrUnix
#3 posted 02-28-2016 02:37 AM
- AlaskaGuy
Pretty sure Collins Tool Co. is a different company than Collins Quality Tools, and they don’t appear to make or distribute any power tools such as a planer, now or in the past. Doing a search for that model turns up lots of hits for a replacement belt, but that’s about it!
View Bud2's profile
Bud2
#4 posted 02-28-2016 02:51 PM
- AlaskaGuy
Pretty sure Collins Tool Co. is a different company than Collins Quality Tools, and they don t appear to make or distribute any power tools such as a planer, now or in the past. Doing a search for that model turns up lots of hits for a replacement belt, but that s about it!HI, I too have only found belts, guess I will have to take it apart and I am sure I can find something I can make fit? I am pretty good at making things from nothing so this be a good project I guess? Like to find a owners manual but will keep looking, Thanks
- MrUnix
View MrRon's profile
MrRon
4771 posts in 3244 days
#5 posted 02-28-2016 04:47 PM
I bought a Collins planer new many years ago; maybe 25 years. I have used it a lot; very happy with it. I have never sharpened the blades, but I’m pretty sure they need it.
View BysWoody's profile
BysWoody
1 post in 561 days
#6 posted 11-12-2016 04:38 PM
https://mywoodcutters.com/Replacement_Knives_for_Planers_and_Jointers/Steel_Carbide_Corrugated_Knives/Planer_Jointer_Carbide_Knives/Planer_Jointer_Carbide_Knives_upto14/Planer-Jointer_Carbide_Knives_SBC125075125-2 and http://www.southeasttool.com/images/SEToolCatalog2015.pdf Part Number: PKC 7057 or PK 7056.
To change the blade (Only one) raise the head up to the top of the carriage, rotate the cutter wheel until you see a black metallic piece the length of the wheel this is the clamp mechanism. it has multiple 10mm hex screws that are holding the clamp bar to the blade. releasing these will release the blade. if you have a 90 degree pick it can be inserted behind the blade at the point that the depth adjustment screws meet the back of the blade. These screws will be used to set the protrusion of the blade from beyond the clamping mechanism once it is sharpened. The planer comes with a carbide tipped blade that is 1/8” thick X 3/4” wide X 12 1/2” long. Must be sharpened by a professional sharpening service. My diamond sharpener didn’t even come close.
I’m hope this is not necesssary to say but I will just for grins…...Please!!!! unplug the planer before trying this. the cutter wheel can be rotated by hand easily.
View Roosterman's profile
Roosterman
1 post in 1018 days
#7 posted 11-20-2016 08:24 PM
I have a Collins Quality Tools 12” Planer. It has two blades not just one. The black bar holding the blade in place is called the gib. The bolts that hold it in place on mine are 9mm. The two set screws at the bottom of the blade to raise it to the proper height. The blades out of my grizzly 12” are the samey same. To set mine I use the same jig that came with my grizzly. I’d like to find a PDF owners manual for it.
View Bud2's profile
Bud2
#8 posted 02-16-2017 03:00 PM
HI, Thanks for info, what I did was run some oak 4×4 threw it and missed couple small nails, [not good for blades] will try get them out,
MrRon
#9 posted 02-16-2017 06:40 PM
Good planer, but it is the noisiest tool in my shop.
View Bud2's profile
Bud2
#10 posted 02-16-2017 07:28 PM
HI, just got finish with the blades on planner, THANKS for info they were not to hard to do at all, they were double sided sharp so just switch them around and WOW what a difference.
