Any idea if how to bore the round stock?
« back to Joinery forum
Forum topic by ruco posted 02-28-2016 12:43 AM 500 views 0 times favorited 3 replies Add to Favorites Watch
View ruco's profile
ruco
22 posts in 786 days
02-28-2016 12:43 AM
I am working on a piece of furniture with 1” round stock and I don´t know how to cut and join these 2 pieces of round stock, and have everything flush.
Any idea of how to do this?
Your help is very much appreciated,
Thanks!
3 replies so far
View MadMark's profile
MadMark
979 posts in 1419 days
#1 posted 02-28-2016 01:01 AM
Forstner bit the same dia as rod. Use a V-block to hold it steady.
M
View Dark_Lightning's profile
Dark_Lightning
3146 posts in 3075 days
#2 posted 02-28-2016 01:03 AM
Drill a hole in a piece of wood and set the rail (horizontal piece) in it. Then run a router with a core box bit that is that diameter of the leg across it to make the cove shape. You want it buried in another piece of sacrificial wood to avoid tear out. That is one way. More people will be sure to chime in, soon.
-- Random Orbital Nailer
17950 posts in 1823 days
#3 posted 02-28-2016 01:23 AM
+1 on the forstner bit, preferably with a drill press. Just be sure you’re over the center of the dowel.
