Good finish for padauk?
Forum topic by Sgt_Lobo posted 11-25-2007 06:49 AM 19037 views 1 time favorited 22 replies Add to Favorites Watch
View Sgt_Lobo's profile
Sgt_Lobo
87 posts in 4092 days
11-25-2007 06:49 AM
Topic tags/keywords: padauk bubinga zebrawood walnut cocobolo finish
Hi all,
Well, my Christmas boxes are coming along nicely and now it is time for me to start contemplating the finishes I will be using. I have been searching the web and am not finding out much about finishing padauk. I am looking for a finish that really makes it stand out with it’s rich color, and at the same time I understand that padauk will eventually change colors on me and possibly turn brown. Is there a good finish that will stave off this browning?
And while we are talking about finishes, I also have pieces of bubinga, zebrawood, walnut, and cocobolo which I need to figure out as well, so suggestions would be most welcome…
-- Sgt_Lobo -- Aurora, CO
22 replies so far
Douglas Bordner
4035 posts in 4297 days
#1 posted 11-25-2007 07:43 AM
UV light causes the padauk to lose it’s bright color. Michael Dresdner has suggested that Armour-All (the car stuff) will help prolong the change in color and limiting exposure to sunlight will also help. Unfortunately Armour-All contains silicon which causes fisheye (craters) to form in film finishes, so an oil based finish like Danish oil or Boiled linseed oil (BLO) maybe the only choice if you pre-treat the wood with Armour-All. I have pretty much banned any silicon containing material from my shop, as I usually finish with lacquer or shellac. Just be careful with the stuff if you ever plan to get into film finishes. Another alternative is to finish with whatever you like and put Armour-All over the top when the finish cures. Paduak will darken over time, no matter what you use.
We like when the darkening occurs over time with Cherry. Paduak, Purpleheart just will darken over time eventually. it’s just an unfortunate fact of the wood.
Sgt_Lobo
#2 posted 11-25-2007 08:18 PM
Thanks Douglas for the advice. I was actually thinking of maybe using Danish oil. I have never considered armour-all. I may have to research that some more. With oil based finishes like danish or teak oil, can you put paste wax over top after the oil has dried?
35152 posts in 4634 days
#3 posted 11-25-2007 08:49 PM
I don’t know if shellac will cover-up the armor-all treatment.
Penofin makes a 99% UV penetrating oil finish. It’s an outdoor marine finish, used for mahogany boats and log cabins. I’ve used it but have never tried to test it against another finish over time. They say it works.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
View Sawdust2's profile
Sawdust2
1466 posts in 4321 days
#4 posted 11-25-2007 11:38 PM
Thanks for the clue, Doug. I’m abut to turn a few pens out of padauk.
As they are intended to be Christmas pens I want to keep them as red as possible.
Douglas Bordner
#5 posted 11-26-2007 12:07 AM
Danged if I can lay “hands” on the exact link I read when I posted yesterday. But this is to the site where Dresdner posts some real honeys on finishing.
Sgt_Lobo
#6 posted 11-26-2007 12:32 AM
Great site Douglas, thanks for the link! He seems to recommend a UV inhibiting urethane. I will research more before making a decision, and I will hope that others continue to post recommendations in this thread…
Douglas Bordner
#7 posted 11-26-2007 02:30 AM
Somewhere in there was the original one about armour-all too. The only draw back about the UV inhibitors which would be in spar varnish and the urethane is that they will muddy up the grain, which the armour-all with a Danish oil follow up won’t do. My answer is to use Cardinal wood (aka Bloodwood) which doesn’t fade. Redheart, another highly colored wood does fade or mellow to more brownish tints. Bloodwood stays rich and red. I have a Padauk 1˝x12˝x48˝ up on the shelf that has been there since I found out about this.
View Dan'um Style's profile
Dan'um Style
14179 posts in 4216 days
#8 posted 11-26-2007 02:32 AM
love the colors either way ! darkened or newly cut !
View Chris 's profile
Chris
1879 posts in 4225 days
#9 posted 11-26-2007 04:23 AM
Sgt,
Thanks for the post. I have just acquired two pieces of Padauk that are 6/4 21”x 15’ (both from the same tree) for a steal and was planning on making a desk from it. I had heard that the wood goes through quite the color change as it ages. I think I be ordering some of that Penofin Oil finish for that project.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
Sawdust2
#10 posted 11-26-2007 05:27 AM
I, too, did a little research
http://www.woodweb.com/knowledge_base/Characteristics_of_padauk.html
Robert Sorby’s web site says use Danish oil whist sanding. Keeps the dust down and fills the pores
Like cocobola it is a nasal irritant so make sure you wear a dust mask.
View Dusty56's profile
Dusty56
11830 posts in 3921 days
#11 posted 05-18-2009 05:59 PM
Thanks for all of the information gentlemen : )
117416 posts in 3811 days
#12 posted 05-18-2009 06:06 PM
Armour all may save your color but contains silicone that will fish eye when in contact with clear coats. or many other finishes . if you use it don’t use it were you will finish other projects because it will contaminate
your other work.
Dusty56
#13 posted 05-18-2009 06:10 PM
Thanks for the heads-up regarding the contamination , Jim : )
View windsurf_mike's profile
windsurf_mike
1 post in 2744 days
#14 posted 07-13-2011 12:22 AM
I’ve been using automotive clear top coat. As far as I know, it has the best UV blocker there is. So far nothing has changed color or tone.
16281 posts in 4452 days
#15 posted 07-13-2011 01:51 AM
I’ve worked a fair bit with padauk. My experience is that an oil finish like Danish oil or BLO will darken it considerably. Poly by itself will keep the color bright. If you keep it away from sunlight, it will retain i’s color.
