| Forum topic by Bradford | posted 1186 days ago | 6087 views | 0 times favorited | 25 replies | ![]() |
1186 days ago |
Topic tags/keywords: help pm66 motor 3hp 1ph Hi gang, I bit off more than I could chew by buying an industrial table saw from last month’s online auction. I thought I could simply swap out the motor, 5HP 3PH, with a 3HP 1PH motor. But apparently the frame type is obsolete. I can’t find a single distributor that sells replacement motors than match up to my Powermatic 66 saw. I’ve spent hours hunting online for a used one and even a universal type that would suffice. No luck in it. If anyone can re-direct me to the exact motor distributor. Thanks. Bradford UPDATE: After reading everyone’s great advise, I went to Powermatic to buy parts. Believe it or not, they still stock EVERY part for their equipment! Info is included below. -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
25 replies so far
#1 posted 1186 days ago |
You may be able to get a VFD to run the 3 phase motor from single phase. -- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html |
#2 posted 1186 days ago |
Have you thought about a phase converter for the saw? For about $200, you can buy a phase converter that will allow you to run 3 ph on a single phase. Give the guys at Grizzly Industrial a call, they can probably help you out and answer some questions you may have. I have installed them for bigger motors 20 hp and up and they work great. Takes a little while for the motor to wind up but saves thousands for a new motor or even more for a electrical service upgrade. -- Methods are many,Principles are few.Methods change often,Principles never do. |
#3 posted 1186 days ago |
VFD? I’m sorry, I’m not sure what that is, but I am sure glad you read my query and at least this points me in another direction. Thanks Gerry. I just went to wikipedia and looked it. It looks like my answer. Thnks. -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
#4 posted 1186 days ago |
Thanks Unionlabel -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
#5 posted 1186 days ago |
It might be easier to get a rotary phase coverter and leave the 3 phase motor in the saw. You would just need one big enough to power the saw. -- Wayne - Plymouth MN |
#6 posted 1186 days ago |
C flange motors are far from obsolete. These aren’t like the motors on Unisaws where the motor mount only fits the Unisaw. Amazon stocks the 3 hp motor for the 66 but they’re expensive. http://www.amazon.com/Powermatic-6472335-Horsepower-Replacement-230-Volt/dp/B0009H5KEK |
#7 posted 1186 days ago |
Ebay can be a good source for them. Make sure they are single phase and the RPM is correct. -- Oldworld, Fair Oaks, Ca |
#8 posted 1186 days ago |
Thanks Wayne, I verified with and electrician friend, Then checked pricing, at $500 for the one need, I think I’ll try the baldor motor on Amazon, if powermatic comp. rep verifies the perfect fit. -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
#9 posted 1185 days ago |
you bit off a problem. a fixable problem, but a problem nontheless. so did I about a year ago. I bought a 2hp 3ph jointer. i’d recommend you head on over to www.owwm.com and search VFD – Variable Frequency Drive. They have some wiring diagrams you will probably need. I assume you have a magnetic starter. Also check with the guys at Factorymation. http://www.factorymation.com/ They talk to 4 or 5 folks like you and me every day about this problem. Those who bite before they know what they are biting. Make sure you write down all of the information on your motor tag. Factorymtion will ask a bunch of motor questions. They will likely recommend something from their TECO FM 50 line of AC drivers ($150 to $250). This is really who you need to be talking to if you have no choice but to keep the 3phase motor. Good luck. -- david roberts, spinning Tales from Topographic Oceans, no, really. |
#10 posted 1185 days ago |
A variable frequency drive for $200 plus or minus would be a much better investment than a new single phase motor and new magnetic controls. I hope Bradford takes the time to check this out. I’ve bookmarked the factorymation site for my own future use. |
#11 posted 1183 days ago |
UPDATE: I called the friendly staff of POWERMATIC, and asked about my problem. They informed me that they still carry the 3HP 1Ph motor and switch box. All for about the same cost as the VFD.
I hope that this will help any future LJ’s if they run into this situation. -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
#12 posted 1182 days ago |
Sounds like you made the right choice. Hope it all works out for you. -- Emmett, from Georgia |
#13 posted 1182 days ago |
It might be worth you while to check with Grainger Industrial Supply. They sell replacement motors for all sorts of things. I picked up a 3HP single phase motor for my old unisaw. -- ~Jason~ , Albuquerque NM |
#14 posted 1180 days ago |
You made the very best choice, even if you have to pay more. The VFD is just one more thing that can go wrong. -- david roberts, spinning Tales from Topographic Oceans, no, really. |
#15 posted 1161 days ago |
I, with the supreme help from my friend Cam, finished installing a new motor and a new magnetic switch. I bought them from Powermatic, who were still cheaper than anyone else. I cleaned / sanded everything on the inside and out. I used 80 grit sand paper on a random orbital sander. Sanded down the whole thing to bare metal, repainted each side of the base with “Hammered metal deep Green” from Rust-o-leum. It was the closest color to the original green that was used 33 years ago. I spent about a week scraping, grinding and sanding the inside in order to get it back to a pre-pitched state. The top was sanded and then steel wool was used to smooth out the scratches. Johnson’s paste wax was used to make the top slick. The rails and fence were reinstalled. A zero clearance insert and push stick were made. The Incra miter gauge 100SE was calibrated and installed. A flicker page was created to show the process. The web page displays them from the finished state going backward to the original state. I hope this will help anyone who wants to buy and restore an old PM66 table saw. here is the link http://www.flickr.com/photos/bradfordwoodworks/ -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
