Need alternative...
« back to Joinery forum
Forum topic by leftcoaster posted 02-27-2016 01:25 PM 594 views 1 time favorited 10 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
202 posts in 781 days
02-27-2016 01:25 PM
I like the plans for this bed
http://www.thedesignconfidential.com/2014/11/free-diy-furniture-plans-how-to-build-king-sized-sienna-platform-bed
But he uses pocket screws and glue to connect the side rails with the head and foot board. That would prevent disassembly.
What’s a better option? Half lap on the legs to the depth of the rails and then screws? Bed hanger hardware?
I don’t have any plans to move it in the foreseeable, but moving an assembled frame up the stairs is a hassle all on its own. Yes, I could assemble on site.
Ideas?
Also, do pocket screws for the slats seem acceptable or should I choose something more elegant?
10 replies so far
17547 posts in 1761 days
#1 posted 02-27-2016 02:15 PM
For this bed which has very large timbers I used mortise and tenon. The 4×8 rails had tenons on each end and the headboard and footboard had mortises. I used some 1×1 angle to make brackets which I then also mortised into the rails and ends. Large lag screws went thru the brackets to hold the mortise and tenons together. I mortised the brackets so they wouldn’t interfere with the mattress. Worked great.
View joey502's profile
joey502
520 posts in 1422 days
#2 posted 02-27-2016 02:47 PM
Pockets screws will not hold up to the racking forces a bed sees. Knock down hardware designed for attaching bed rails to the head/ footboard are a great option.
I do not feel pocket screws are a good option for assembly on the head and footboard either. Beds see all kinds of force, none of which a pocket hole joint will fair well against. The twisting when people flop down, roll around and get busy will pull the screws out. Gluing endgrain to long grain before the screws are applied will not add much strength. Endgrain does not glue well.
View Ger21's profile
Ger21
1074 posts in 3036 days
#3 posted 02-27-2016 02:58 PM
Buy some quality bed rail mounting hardware. It’s very strong, and makes for a knockdown assembly
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View bearkatwood's profile
bearkatwood
1478 posts in 916 days
#4 posted 02-27-2016 02:59 PM
I have built a few beds and always go for this one unless I am using through bolts.
http://www.rockler.com/heavy-duty-wrought-steel-bed-rail-fasteners-4-pack-select-size
-- Brian Noel
116902 posts in 3482 days
#5 posted 02-27-2016 03:04 PM
I agree with the previous folks use mortise and tenon joinery or even counter sunk holes with screws and plugs for the joinery ,is better than pocket screws.
View jbay's profile (online now)
jbay
2042 posts in 804 days
#6 posted 02-27-2016 03:14 PM
I would go with the tried and true hardware Brian mentioned above.
If you don’t mind the hardware being on the inside I made a waterbed frame and joined the pieces using 1 1/2” aluminum angle. worked great and was fast and easy and strong. The cushion will hide the hardware.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
leftcoaster
#7 posted 02-27-2016 03:53 PM
OK, so mortise and tenon for the headboard pieces and rocker hardware for the knockdown rail assembly.
Bill, your bed is beautiful. How do you safely cut tenons on a long, heavy board like those rails?
#8 posted 02-27-2016 05:21 PM
I cut the shoulder cut with a circular saw running against a guide. Then I cleaned out the rest with a router and straight bit. For the mortise I used a forstner bit and the squared it up with chisels. The tenons were only 1” long. They just needed to support the weight. The brackets keep the tenons in the mortises. You could do it other ways. You could do it all with a router and a jig. It would be easier to make round cornered mortises and then round the corners of they tenon than to do the opposite. Thanks on the bed. I built that for my cousin from all yellow pine.
runswithscissors
2653 posts in 1930 days
#9 posted 02-27-2016 09:41 PM
All Yellow Pine? A guy I knew in the army came from there.
#10 posted 02-27-2016 10:03 PM
Not Al. All.
