A brush with death...
Forum topic by Bothus posted 02-26-2016 08:14 PM 962 views 0 times favorited 8 replies Add to Favorites Watch
View Bothus's profile
Bothus
441 posts in 3417 days
02-26-2016 08:14 PM
Topic tags/keywords: question router
Well okay, these brushes aren’t exactly dead yet.
But they will die and when they do I want to have replacements at the ready.
The only problem is I have no idea what make and model this router is. It was modified by someone for a specific purpose before I inherited it and I don’t have any documentation or even any other parts. There are not labels on it.
I thought it was Makita because of the shade of blue but I can’t find any Makita’s that look like this.
Does anybody know what this is?
Thanks in advance.
-- Jerry Boshear, Professional Kitchen Designer, amature woodworker.
8 replies so far
View teejk02's profile
teejk02
489 posts in 1366 days
#1 posted 02-26-2016 08:31 PM
Trim router I guess…I think Makita had more of a turquoise color. Looks too solid to be a HF thing (although that radiator clamp might say otherwise). No branding ID on it anywhere? That in itself tells you it is a “no-name” I think. An electrical shop can probably get you close.
View JoeinGa's profile
JoeinGa
7740 posts in 2248 days
#2 posted 02-26-2016 09:03 PM
Bring one into any electrical supply, they should be able to match it up for you.
View bold1's profile
bold1
310 posts in 2088 days
#3 posted 02-26-2016 09:24 PM
Electrical supply, electric motor rebuild shop, even a lot of hardware stores in their specialty bins, stock carbon brushes. I’ve even made replacements for some odd tools from the carbon rod in a D cell battery.
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#4 posted 02-26-2016 09:28 PM
That’s a Bosch, my grandpa used to have one like that, I’ll do some research and see if I can figure out the model number.
Bothus
#5 posted 02-28-2016 08:18 PM
That s a Bosch, my grandpa used to have one like that, I ll do some research and see if I can figure out the model number.
- bigblockyeti
Thanks Big. I look foreword to hearing from you.
Joe and Bold, thanks I may need to do that.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1053 posts in 1307 days
#6 posted 02-28-2016 08:40 PM
Looks like an older Bosch Colt. The older ones have a pretty torquey start up and without a base for it would make it very unsafe.
-- "Tying shoelaces was way harder than learning to Whistle"
bigblockyeti
#7 posted 02-29-2016 01:01 AM
Well, I looked high and low, everywhere I could and I can’t find any information on that router. I can’t even find any information on any of the early Bosch routers. The only other avenue I have is an old books of parts lists for several Bosch tools, problems is I have no idea where I put it.
Bothus
#8 posted 02-29-2016 01:26 PM
Thanks Turtle. You are correct it is a little dangerous without a base but it is used for a specific purpose cutting a groove around a French curve on a cabinet apron so the base had to be removed. I’ll give some thought to ways I can modify it to make it safer. I appreciate your input.
Big, I haven’t found anything like it on the web. I went through every Bosch model number on ereplacements.com and didn’t see anything with this teardrop shape on the motor housing. I’m beginning to think teejk02 is correct and it is a no name brand. Seems to be well built though.
I did measure the brushes and they are 5mm X 8 mm so I found some 5 X 8 X 13 that 8 ordered to see if they work.
If you do run across it later though be sure to let me know. I’m not going anywhere.
