(Not exactly a woodworking tool)Recommendations or a good stud-finder?
Forum topic by Millo posted 02-21-2010 03:52 PM 3681 views 0 times favorited 29 replies Add to Favorites Watch
View Millo's profile
Millo
543 posts in 3048 days
02-21-2010 03:52 PM
Hello,
Here I am annoyingly requesting another tool recommendation. We need a reliable stud sensor, and it seems all reviews I read about most models describe them as a nightmare, almost regardless of price. Do I need to go over $40 to get one that’ll not drive me to turn my walls into Swiss cheese? I did find an online comparison test that recommended a Stanley model that might not be made anymore, or at least that isn’t readily available around here—I’d rather buy it here than wait to have it shipped. I did look at the current Stanley ones around the same price as the recommended ones and saw the typical nightmarish reviews—”piece of junk”, “I wish I had read these reviews before buying”, “drilled 5 holes, found 1 stud”, etc…
Does anyone have any recommendations?
Thanks!
29 replies so far
View mtkate's profile
mtkate
2049 posts in 3324 days
#1 posted 02-21-2010 03:56 PM
The problem I always have is where electricity confuses the tool. But I try to count on the fact that walls are constructed to code so I try to find one stud and work outward with the stud finder (yes, it’s about $40) and tapping with my knuckles to hear changes in sound.
However, it does not always work. I am fearless when it comes to opening drywall and redoing it do it does not bother me too much. I admit, it’s a pain!
View miles125's profile
miles125
2180 posts in 4004 days
#2 posted 02-21-2010 04:03 PM
I have better results using intuition like locations of elec outlets, visible nails and tapping with my knuckle than any stud finder i’ve ever used.
-- "The way to make a small fortune in woodworking- start with a large one"
16274 posts in 4217 days
#3 posted 02-21-2010 04:12 PM
I use the same method as miles125… look for clues, tap for sound,, and, when you’re pretty sure, drive a small finishing nail to see if you hit something. If you miss, small nail holes are easy to fill.
View richgreer's profile
richgreer
4541 posts in 3073 days
#4 posted 02-21-2010 04:49 PM
I’ve basically given up on stud finders. I’ve owned several, including some more expensive ones, and I find that I can never rely on them. However, if you buy one I have one tip – fresh batteries. Use fresh new batteries every time and then save those batteries for other applications (TV remote or whatever).
View Sawkerf's profile
Sawkerf
1730 posts in 3067 days
#5 posted 02-21-2010 06:03 PM
I have two stud finders that just collect dust in my shop drawers. Visual cues (electrical boxes, wall corners, etc) a tape measure, and a knuckle are the most reliable.
I did use one last summer, however. I was delivering some furinture to a (very attractive) lady customer who asked me to help her hang some pictures. She had a stud finder and wanted me to teach her how to use it. I installed the battery, held it against my chest, and pushed the button. When the light came on, I said “Ok, it works” and stepped toward the wall. After a brief look of confusion, she “got it” and collapsed in laughter.
When she recovered, I showed her my method and told her to return her stud finder – or use it to entertain her friends. – lol
Millo
#6 posted 02-21-2010 07:48 PM
Sawkerf—funny.
Yeah, I did use the knuckle method but missed once. I guess I misinterpreted the sound. I’ll the tape measure/outlet/light switch method. Thanks guys!
Sawkerf
#7 posted 02-21-2010 08:06 PM
The knuckle trick isn’t foolproof, but you’ll get better with practice. Verifying with a small finish nail usually seals the deal, and a hole or two is easily fixed.
View dfarr's profile
dfarr
19 posts in 3430 days
#8 posted 02-21-2010 08:37 PM
Check out the lowtech STUD4SURE available on Amazon. After reading all the negative reviews of the electronic gizmos costing $25 – $100 dollars and patching holes caused by the knuckle method I purchased the older version of this. Mine works remarkably well and based on the reviews on Amazon it appears the new model does too. Currently listed for $10 (with free shipping on $25 orders) I’d recommend you give one a try.
View TroutStalker's profile
TroutStalker
30 posts in 3367 days
#9 posted 02-21-2010 08:42 PM
I’ve given up on stud finders. I use a rare earth magent; it will stick to drywall nails or screws. When I feed a need to verify I use an icepick – makes a smaller hole than a finish nail.
-- The best thing online is a fish
View KMJohnson's profile
KMJohnson
165 posts in 3019 days
#10 posted 02-21-2010 08:45 PM
Zircon, makes good scaners.
-- Let's do it in the wood pile!
View ahock's profile
ahock
102 posts in 3322 days
#11 posted 02-21-2010 09:01 PM
I use some cow magnets (the ones that you shove down their throats to collect the little bits of metal that they might swallow..) I take one and tie a string around it and hang it from my hand and slowly swing it back and forth against the wall. It will grab onto screw or nail heads and stick.
-- Andy, PA ~Finding satisfaction in creation
TopamaxSurvivor
18271 posts in 3674 days
#12 posted 02-21-2010 10:20 PM
I’m with ahock. I never see a stud finder on a job being used by a carpenter. They all carry cow magnets. I tried two or three and never had one that worked very well.
Millo
#13 posted 02-23-2010 12:00 AM
cow magnets? Had no idea that was needed for cows. Hmm… I’ll look into that.
View Eric_S's profile
Eric_S
1565 posts in 3194 days
#14 posted 02-23-2010 02:02 AM
Ive tried a few different stud finders (Zircon, Stanley, Black and decker), even the ones that have wall thickness adjusters or electric sensors, and they have all caused me to drill numerous holes, all of which didn’t hit studs. What was supposed to be a quick and easy task with a stud finder turned into a tedious chore. Now I just use the finish nail technique like others have mentioned.
Cow Magnets? Never heard of them but sounds like a good idea. Where do you get those?
-- - Eric Noblesville, IN
TopamaxSurvivor
#15 posted 02-23-2010 02:49 AM
Feed stores or veterinary supply
showing 1 through 15 of 29 replies
