Cleaning your cutting tools?
Forum topic by jayjay posted 02-21-2010 05:55 AM 1260 views 0 times favorited 14 replies Add to Favorites Watch
View jayjay's profile
jayjay
639 posts in 3244 days
02-21-2010 05:55 AM
How or what do you guys use to clean the pitch and build up on the cutting blades of your table saws, routers, jointers, planers, etc. I know there are cleaning product kits that you can buy to soak your blades in, but I’m more interested in home made remedies that I might be able to make using things that I might already have lying around my shop. Are there any tricks, techniques, or special mixtures that clean off the crusty build up?
-- ~Jason~ , Albuquerque NM
14 replies so far
View NBeener's profile
NBeener
4816 posts in 3373 days
#1 posted 02-21-2010 06:06 AM
I do pretty well with a 50/50 mixture of Simple Green and water, scrubbed with an old toothbrush, or the current toothbrush of somebody you don’t particularly like.
Hint: table saw blades soak pretty comfortably in an inverted Frisbee :-)
-- -- Neil
View yuri's profile
yuri
136 posts in 3802 days
#2 posted 02-21-2010 06:07 AM
+1 to Neil
I clean the same way.
Here
jayjay
#3 posted 02-21-2010 06:11 AM
^^I’ll give that a try. I know plenty of people with tooth brushes…....lol
13640 posts in 3540 days
#4 posted 02-21-2010 06:18 AM
http://lumberjocks.com/topics/11655
http://lumberjocks.com/reviews/brand/208
jayjay
#5 posted 02-21-2010 06:25 AM
Thanks for the links David.
View dfdye's profile
dfdye
372 posts in 3236 days
#6 posted 02-21-2010 06:55 AM
Never have heard the frisbee trick. I’ll have to use that one! Right now I use a giant Rubbermaid tub—too big and needs too much cleaner. Thanks for the tip!
-- David from Indiana --
#7 posted 02-21-2010 07:01 AM
the one i was also looking for ,
was the one about cutting
the bottom of a plastic pail
2 or 3 inches and soaking the blades in that .
View Sawkerf's profile
Sawkerf
1730 posts in 3267 days
#8 posted 02-21-2010 07:23 AM
I use Simple Green in those throw away aluminum pizza pans from the grocery store.
NBeener
#9 posted 02-21-2010 07:23 AM
I only seem to have one Frisbee that’s big enough for a 10” ts blade.
I think IT’s the odd man out.
The others are only big enough for a circ saw blade, so … I like David’s bottom of the bucket idea ;-)
-- -- Neil
View cbMerlin's profile
cbMerlin
100 posts in 3619 days
#10 posted 02-21-2010 02:32 PM
I’ve tried everything from oven cleaner, bug & tar remover, wd40, kerosene, commercial degreaser, just about everything. CMT’s formula 2050 is hands down the best I’ve used. About once a year a pick up a container from Wordwerks, 18oz bottle, I thinks it’s around $15-$20. I also picked up a oil change pan from one of those dollar stores several year back that holds a TS blade perfectly. I also use a toothbrush, but being ever on the look out for easier ways to do things, I spotted a battery powered toothbrush at CVS on sale for a couple bucks. Between the two, my blades look new!
-- Sawdust looks better in the garage than cars, explain that to your wife!
View Brian024's profile
Brian024
358 posts in 3599 days
#11 posted 02-21-2010 03:41 PM
Simple Green
View douglbe's profile
douglbe
369 posts in 4160 days
#12 posted 02-21-2010 04:17 PM
Same here, Simple Green!
-- Doug, Reed City, Michigan
View JayPique's profile
JayPique
61 posts in 3487 days
#13 posted 02-21-2010 04:36 PM
I use an old Tupperware pie holder to clean my blades. It’s got a lid that seals nicely and I keep the Simple
Green solution right in it between cleanings. Works great. I just wish I could find one that was big enough for a 16” blade.
JP
jayjay
#14 posted 02-21-2010 05:34 PM
Sounds like simple green is the winner. Good thing is, we use that stuff by the 55 gal. drum where I work, so I have pretty much an endless supply of that. We use it mainly to clean oil and coolant off parts that we machine, I never considered it for cleaning pitch and gum off blades. Thanks again for all the tips and suggestions.
