weak wood solution
Forum topic by MsDebbieP posted 2299 days ago 812 views 0 times favorited 5 replies Add to Favorites Watch
18320 posts in 2332 days
2299 days ago
I made a new tool for my clients yesterday, that is a series of “waves” (cut on the scroll saw). The two outside “waves” are fixed to the base and the inside 2 slide.
I created the entire thing out of pine.
Problem: the top of one of the waves snapped off.
Prevention: should I have coated everything with several coats of urethane or something so this wouldn’t have happened?
Solution: I can glue the piece back on.. but now what? How do I keep the rest of them from snapping off as well?
5 replies so far
View Thomas Porter's profile
Thomas Porter
127 posts in 2302 days
#1 posted 2298 days ago
If you had a picture of it that would help. With pine, I usually find that grain direction can really hurt you when it comes to strength in fixtures. Sometimes I like to use hardwoods and either laminate them to the softwoods or forget the softwoods all together if it requires alot of strength.
-- Thomas Porter, Phoenix, AZ, www.thomasporter.com
dennis mitchell
3994 posts in 2485 days
#2 posted 2298 days ago
Debbie a finish would not have stopped this from happening. They might all break of if your waves are to skinny.(no strength) It might have just been a flaw in that board. Glue it back and you will probably be ok. Next time try a different wood. That is how we learn where to put what type of wood. Poplar might have been a good cheap wood to use.
Dick, & Barb Cain
8681 posts in 2470 days
#3 posted 2298 days ago
Debbie
For small things like this, some thin Birch plywood would ideal, & if you wood burn, a lot of woodburners use it for their work. You can buy a 2’ x 4’ piece fairly cheap, & make lots of things with it.
#4 posted 2298 days ago
thanks everyone for your guidance.
I’ll add these wood alternatives to my list.
View oscorner's profile
oscorner
4565 posts in 2482 days
#5 posted 2297 days ago
I agree with, Thomas. The grain direction is very important. When laying out your waves, you need to make sure that the tips of your waves have the long fibers of the wood running from the bottoms to the tips. This is where the strength of the wood lies. Birch plywood works because plywood is layered with the grain crossing in opposing directions, thus making its strength equal in all directions, even though maybe not as strong as wood fibers would be in a board. This strength is sought after in chair building, thus the reason why the legs and rungs are made from rived wood instead of cut lumber. In rived wood the wood fibers are continuous from end to end, where as in cut lumber these fibers may have been cut through by the saw, depending on the way the wood was sawn.
-- Jesus is Lord!
