Cutting mortises with a plunge router?
Forum topic by Beginningwoodworker posted 02-20-2010 06:08 AM 7328 views 0 times favorited 31 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3670 days
02-20-2010 06:08 AM
I am looking getting a Milwaukee 5615-24 for cutting mortises. You guys know I told you I wonted to try my hand at some morris chairs for my mom, I am thinking I can use the plunge base to cut the mortises but I am a tough time find a 3/4’’ sprial upcut router bit, I may be better off buying a benchtop mortiser. I am wondering do you guys know where I can find a 3/4’’ sprial upcut router bit.
31 replies so far
View b2rtch's profile
b2rtch
4861 posts in 3045 days
#1 posted 02-20-2010 06:24 AM
Why do you want a 3/4 bit?
You would be better of to cut the mortise in two or more times.
-- Bert
View Mike's profile
Mike
252 posts in 3380 days
#2 posted 02-20-2010 06:27 AM
Hi Charles,
Woodcraft… has Onsrud HSS Spiral Upcut Router Bit, 3/8” D, 1-1/4” CL, 3-3/4” OL, 1/2” SH, Onsrud# 40-135 for a little over $20.00. I did the same thing at first then I ended up getting the Jet Mortisie Machine, the chisel bits works excellent.
Mike
-- Mike, VT
Beginningwoodworker
#3 posted 02-20-2010 06:28 AM
The plan calls for 3/4’’ mortises.
View Eric_S's profile
Eric_S
1565 posts in 3192 days
#4 posted 02-20-2010 06:37 AM
Bosch has one, Bosch 85967M but its very expensive, http://www.nextag.com/Bosch-85967M-NA-SC-506781663/prices-html. You can get away with using a straight bit also, or use a smaller bit and make a template and just use a guide bushing.
-- - Eric Noblesville, IN
Rick Dennington
5857 posts in 3191 days
#5 posted 02-20-2010 06:37 AM
Charles : You might try Rockler, MLCS, Woodpeckers, Amazon.com, and others. I’ve never seen a 3/4” spiral router bit…..the biggest I have is a a 1/2”, but they make make them…don’t know, but somebody on here will. Good luck finding one….... later.
13603 posts in 3338 days
#6 posted 02-20-2010 06:45 AM
like eric said ,
use a smaller bit , and a slightly bigger template and guide bushing .
try it out on scrap first , the big bit will want to jump and tear maybe ,
the smaller one will be much calmer and just do more passes .
View matt garcia's profile
matt garcia
1892 posts in 3669 days
#7 posted 02-20-2010 06:53 AM
I would get the mortiser, but remember, the largest chisel they give you with it is a 1/2” You could always lay them out, then drill out the majority of the mortise with your drill press, then chisel them square.
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
Beginningwoodworker
#8 posted 02-20-2010 06:55 AM
I think you can get a 3/4’’ mortise chisel.
teenagewoodworker
2727 posts in 3765 days
#9 posted 02-20-2010 07:00 AM
Eric_S thats quite a bit… but it’s a 3/4” diameter shank. and its 4” in length!!!! that’s giant!!!
#10 posted 02-20-2010 07:08 AM
charles ,
http://grizzly.com/products/mortising-machine/g9976
they have a 3/4 bit there too .
Beginningwoodworker
#11 posted 02-20-2010 07:17 AM
Thanks guys, I am going to get the Delta 14-651 benchtop mortiser. I think Home Depot has it for $249 free shipping.
View jack1's profile
jack1
2107 posts in 4024 days
#12 posted 02-20-2010 08:50 AM
I have that mortiser. It’s a good one for the price and you can get a 3/4” chisel for it. Good luck and practice on a bunch of scrap! ;0)
View Mike's profile
Mike
#13 posted 02-20-2010 02:50 PM
You might have to buy the rest of the chisel set, not famaliar with the Home Depot in your area. The chisel are very sharp and do a remarkable job.
-- Mike, VT
View jcsterling's profile
jcsterling
462 posts in 3582 days
#14 posted 02-20-2010 04:23 PM
Your asking a lot from the machine to chop a 3/4 mortise. You have to have some serious power and leverage . If I want a mortise that big I cut it in 2 passes using a 3/8 bit , I am using a general int 75-075 with a 1 hp motor.
-- John , Central PA , www.jcsterling.com on facebook: http://www.facebook.com/#!/pages/JC-Sterling-fine-furniture/104430802928776
b2rtch
#15 posted 02-20-2010 04:37 PM
I read good stuff about the HF mortiser and it is just above $120.00 on sale.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=35570
-- Bert
showing 1 through 15 of 31 replies
