Yard Sale Success (Tool Gloat)
Forum topic by Kelly posted 02-24-2016 04:49 AM 965 views 0 times favorited 6 replies Add to Favorites Watch
View Kelly's profile
1939 posts in 2874 days
02-24-2016 04:49 AM
I live well away from civilization, so garage sales are rare. Usually, what we do have aren’t worth hitting, though you do come across the occasional gem.
Last week, a family was clearing out their pop’s garage, in anticipation of moving him across what passes for town here. Since sales are rare, I went. I found a treasure trove of aluminum stock I could use for jigs and even parts for musical instruments. In the end, I probably ended up with about a hundred pounds of stock that ranged from 1/8” 4”x4” pieces to 1/2” thick angle iron (four inches), heavy plates, some 2”x2” and so on.
In one of the bins, I found a Brown and Sharpe dial gauge, so it went into my bin. I also found a couple small squirrel cages and a little DC motor. Then I found what I’d been contemplating for a while – a 3/4 horse, variable speed, DC motor (reversible) with the controller.
Another tub had a couple of the big toggle hold downs sitting on top of some aluminum, so I grabbed that bin too.
They charged me $25.00 for the three bins.
When I got home and went through them, I found a nice metal punch, with interchangeable tips, which was perfect for the wife’s jewelry efforts (she just didn’t know it yet). There were other things too, like a $120.00 (new price) Ridged flaring tool, and saw set, a chuck that fits in my drill press chuck and holds my smallest bits.
I thought about it and figured I might as well go back and buy some aluminum, since it isn’t hard to store and the price was so good. That time around, I ended up with a bin with a thousand dollars, used value, gauges and dials, a box of new metal lathe cutters, a 7.5 amp Variac, a bunch more aluminum, and so on.
That round cost me $20.00
Still high from the DC motor score (looks like my four wheel grinding-buffing station or my drill press will be going to a dial control in the not to distant future), I drove an hour and a half and bought a router carver. It came with the foot pedal controlled rotary dohicky for doing gun stocks and had a little Colt already mounted. This was all mounted on a [damn heavy] two inch thick maple butcher block counter.
That one was only about half of new, so in the area of market value.
I’m already started on converting it so I can slide the gun stock accessories off and slide in a sign making or just light 3-D carving set up that will move the pattern and blank on the X and Y axis.
When done, I intend the whole thing should flip up, after securing the head, so it will only take up about on fourth the room, but still be quick and [relatively] easy to set up.
View Woodknack's profile
11286 posts in 2310 days
#1 posted 02-24-2016 07:21 AM
Nice. What is a Brown I dial gauge?
-- Rick M,
View TheWoodRaccoon's profile
364 posts in 859 days
#2 posted 02-24-2016 12:56 PM
- Rick M.
Brown & Sharpe maybe?
-- still trying to think of a clever signature......
#3 posted 02-24-2016 04:12 PM
Yep, in the course of trying to dump images in, the Net or the site jumbled things and I didn’t get them cleaned. Heck, I couldn’t even get to the edit mode [signed in] and said to hell with it.
View JoeinGa's profile
7733 posts in 1937 days
#4 posted 02-24-2016 06:07 PM
Yep, a nice score like this will get you a big ‘ol
#5 posted 03-24-2016 12:23 AM
Was messing around with finds from that garage sale. The tub which had several hundred dollars in gauges and things had a box of collets ranging in size from 1/8” to 3/4”. I figured they were horse trading stock, but it occurred to me they might be useful on my wood lathe, as I progress in what I do with it. Sure enough, a search shows the collets and the chuck will be useful for fine turning.
#6 posted 03-24-2016 12:24 AM
Pulled the 240 volt motor off my four disc grinder and played with the DC servo motor. I’m happy to say I now have a variable speed grinding station I can run from a couple RPM’s to twenty-five hundred RPMs.
