Plywood Panel Glue Up
Forum topic by Quailguy posted 02-24-2016 04:31 AM 641 views 0 times favorited 6 replies Add to Favorites Watch
View Quailguy's profile
Quailguy
56 posts in 1185 days
02-24-2016 04:31 AM
I want to make a cabinet door panel with 1/4 ” mahogany over Baltic Birch Plywood. The panel is 24×36 and will sit in a rabbet, not a groove. Would glueing the mahogany to the ply (think veneer) be acceptable. I’m worried about seasonal movement and bowing. Any suggestions will be greatly appreciated.
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2844 days
#1 posted 02-24-2016 05:28 AM
I built a shop sawed 1/4” veneer three way booked match cherry headboard four years ago using the technique you described. I just went in to take a really close look. No problems I could see
-- Ken
Quailguy
#2 posted 02-24-2016 05:36 AM
Thanks, Ken
What glue did you use? I usually use Titebond 2 and can’t see why it wouldn’t work here also.
View MadMark's profile
MadMark
979 posts in 1447 days
#3 posted 02-24-2016 06:00 AM
Uhh, why not buy mahogany faced 1/4” ply? Its a stock item.
M
newwoodbutcher
#4 posted 02-24-2016 06:04 AM
I don’t have the container any longer, so I’m not sure. It most certainly was a plastic resin. I don’t know if it matters but I also used a vacuumed bag to clamp it
-- Ken
Quailguy
#5 posted 02-24-2016 06:09 AM
Mark,
I have a small amount of mahogany with very nice grain, I think it will look nice on this wall hanging tool cabinet I’m building. I’m backing it with 1/2” plywood to make it go farther and give the door some thickness so I can hang tools inside the door.
Quailguy
#6 posted 02-24-2016 06:09 AM
Thanks again, Ken, I’ll keep researching.
