Would you use this wood ?
Forum topic by PaulfromVictor posted 02-19-2010 11:32 PM 995 views 0 times favorited 6 replies Add to Favorites Watch
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3521 days
02-19-2010 11:32 PM
This is some wood that I picked up a few years ago at a very low price. I am not sure, it may be beech. As you see, the wood has some pretty serious splits. I guess that it was not dried properly. I could cut out or around the splits, but I do not know what to expect with what is cut out. I don’t want to invest time working with something that will split or warp. I do not have a project in mind for this yet. I have been reluctant to use it.
What do you think? Garbage or treasure?
View DaddyZ's profile
DaddyZ
2475 posts in 3216 days
#1 posted 02-19-2010 11:38 PM
Cut Around the Splits & Enjoy, Splits were more than likely from damp wood or climate change, but “after a few years” should be acclimated for your area.
Enjoy :)
16278 posts in 4394 days
#2 posted 02-19-2010 11:43 PM
I agree with DaddyZ.
View wiswood2's profile
wiswood2
1138 posts in 3871 days
#3 posted 02-20-2010 12:19 AM
Use it I do all the time. Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
27250 posts in 3997 days
#4 posted 02-20-2010 12:39 AM
I tried to find it but I could not locate the video that Charles Neil produced on this. Basically he cut along the split following the grain of the wood with a bandsaw and glued it back together. He did this a total of 4 times on the slab that he was working on that had a split in it and eventually ended up removing the split entirely and was left with a solid board.
View 8iowa's profile
8iowa
1586 posts in 3937 days
#5 posted 02-20-2010 01:18 AM
It looks to me like those splits are too prominent to be caused by natural drying. The splits may be a result of internal stresses in the wood, like a tree forced to grow at an angle, or constantly having to brace into a prevailing wind. I think this is called “reactive” wood. If this is the case, internal stresses may still be evident.
Another possibility is that the tree was improperly cut down, causing it to split deeply as it broke loose.
View KMJohnson's profile
KMJohnson
165 posts in 3196 days
#6 posted 02-20-2010 01:24 AM
Steve Marin can show you how to make a real nice stool out of that wood.
-- Let's do it in the wood pile!
