Techniques for Staining Ends of Boards
Forum topic by DocK posted 02-19-2010 11:28 PM 1210 views 0 times favorited 9 replies Add to Favorites Watch
View DocK's profile
DocK
19 posts in 3179 days
02-19-2010 11:28 PM
Topic tags/keywords: question
I’ve tried different techniques for getting a even color stain on a piece of completed work. But when it comes to staining the ends of any type of board one always gets a darker finish than the closed pores section of the board. Any way, that you might use, to regulate this so the piece comes out the same color end and top?
Thanks
-- DocK
9 replies so far
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3221 days
#1 posted 02-19-2010 11:35 PM
If you can sand it to a finer grit that will reduce absorbtion. You will need to practice on scrap to determine how fine to sand to.
I think you can also seal with shellac, and then stain, but I have never tried that.
View NathanAllen's profile
NathanAllen
376 posts in 3020 days
#2 posted 02-19-2010 11:43 PM
Another option is to use a very low cut of dewaxed shellac, 1lb max and lightly coat the end grain. The stain will work it’s way through the weak shellac at a slower rate, allowing you to wipe off before it becomes too dark.
Other products such as a wood conditioner that is advertised to reduce blotching on close grained woods (pine, maple, etc) work just as well.
Getting it perfect though usually requires less effort than using an edge banding or framing/beadboarding.
View DocK's profile
DocK
#3 posted 02-20-2010 12:36 AM
Thanks all! I tried shellac but must have the wrong type. Wax free isn’t available here so will have to order some. Any brand name you would suggest?
-- DocK
View hObOmOnk's profile
hObOmOnk
1381 posts in 4004 days
#4 posted 02-20-2010 12:42 AM
I recommend Zinsser SealCoat.
-- 温故知新
View GuyK's profile
GuyK
356 posts in 3955 days
#5 posted 02-20-2010 12:48 AM
Zinsser Sealcoat cut 50/50 with denatured alcohol I use it on all projects with pine or cherry to stop blocthing and it also seals the end grains to get a more uniform color. After applying, let dry and sand lightly.
-- Guy Kroll www.thelandsathillsidefarms.org
View DocK's profile
DocK
#6 posted 02-22-2010 08:25 PM
Thanks All
-- DocK
View DocK's profile
DocK
#7 posted 02-23-2010 07:08 AM
Thanks Cessna. I flew a Piper PA 20 several years in Alaska.
I’m really limited here in what I can purchase. Any particular catalog I can get these items from?
Thanks again.
-- DocK
View bob101's profile
bob101
321 posts in 3326 days
#8 posted 02-23-2010 06:03 PM
Min wax wood conditioner before staiming the ends.
-- rob, ont,canada
View DocK's profile
DocK
#9 posted 02-24-2010 02:34 AM
My PA-20 was on tundra tires in the summer and skis in the winter.
Good site. Thanks Cessna
-- DocK
